Changing the Map light bulb in 4th gen
I could not find a write up on this... may be because its very minor thing. I need to replace the bulb in the "map light" (located just above the rear view mirror) but not sure how to take out the bulb from the housing there. I can see a clip there but not sure which way/how to press or bend it so the bulb can be removed and the new one put in.
Thanks.
Thanks.
I had this same problem actually. What you have to do is push the bulb on the glass side and then twist the bulb so thr nubs on the sides of the bulb will slide out. Know what I mean? Those are pretty bad instructions. Good luck finding a replacemrnt bulb tho. I couldnt find a match in any stores.
Thanks 97GreenMaxSE, will try your instructions.. I know the bulb is hard to find, will probably have to go to stealer (read dealer).
Starsnstripes - its not listed in the manual.
VQmaxi17 - thats bizzare... only way I can think of the bugs might have tunneled through the Sunroof housing (thru the hollow).
What are you guys talking about? The replacement of map light is clearly stated in owner's manual. And the bulb is pretty common.
To remove the cover, just use a big flat screw with some clothes padded. The bulb is twist-and-remove thing.
There was a small bug in the light cover. Yes, it happens.
BTW, my max is '99.
BTW, my max is '99.
Has anyone put LED's in it? I have one in mine but when I put in a second in parallel the second one blows, but the first doesn't. They both had resistors. Do yall think it would work if I wired 4 LED's in series to split the voltage (or is it current that splits?). I've already wasted 20 out of my 50 bulbs doing the dome light LED "mod". I don't want it ricey, just bright and clean light.
Originally Posted by VQmaxi17
i know this doesnt answer your question.... but my maplight had like 5 bugs in it when i changed the bulb last year.... did that happen to anyone else???
(just wondering)
(just wondering)
I don't think just switching to LED bulbs is a good idea. Although each LED has a resistor, the total impedance would different according to the configuration (parallel/serial). It's not a smart way at all.
My idea is, I would put a small PCB and transistor/resistors to get proper voltage and limit the current through the LEDs. Perhaps I would use surface-mount LEDs.
This application could be used on the front door curtesy lights.
King_Ten_Ahead
Sep 30, 2015 04:27 PM
Finkle
Sep 27, 2015 09:53 PM
MikesChevelle
Aug 6, 2015 11:36 AM
RealityCheck
Aug 5, 2015 06:18 AM
bassmann
Aug 3, 2015 07:53 PM
