Antifreeze Leak Need help
Old Aug 2, 2006 | 02:30 PM
nanomax96's Avatar
Hello everyone, and thanx for all your help in advance.
The mighty max has a coolant leak and I can't figure out from where.
I have checked hoses and radiator but it's not coming from any of those places. The puddle on the floor is located by the oil pan which made me think it was oil at first but its not its antifreeze. I checked the connection into the engine on the passenger side and it looks dry. Is there a temp. sensor or something else that could be leaking coolant on the passenger side of the engine.
Old Aug 2, 2006 | 02:33 PM
blarg's Avatar
Blah + Arg = Blarg
If you're in my situation I noticed antifreeze leaking around the same area and according to the Haynes manual it is antifreeze leaking from the "weep" hole.
Old Aug 2, 2006 | 02:56 PM
nitromax's Avatar
water pump
Old Aug 2, 2006 | 06:04 PM
nanomax96's Avatar
how do you fix it?
Old Aug 2, 2006 | 07:06 PM
konak85's Avatar
water pump. i had the same leak. You will have to take it to a certified mechanic. Get the timing chain tensioner and guide checked while the pump is being replaced. I got my chain tensioner, guide, and water pump done for $500
Old Aug 2, 2006 | 07:14 PM
blarg's Avatar
Blah + Arg = Blarg
Originally Posted by nanomax96
how do you fix it?
I had to get the water pump replaced. I took it to a mechanic.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Mar 12, 2020 12:06 AM
fastcarny
Oct 12, 2015 07:06 AM
RWCreative
Sep 21, 2015 11:01 AM
