small gap in the sunroof- anyone else has it?
When you look at the longer rear side of your sunroof, do any of you have a little gap where the rubber going around the glass meets? I have a small gap there (big enough to be able to stick the metal part of the ignition key in there (not the handle, though)). When it rains, some of the water gets in and ends up on the sunshade. I know that there are channels for the water to drain in the sunroof assembly (just cleaned them), but it does not look that the water from ontop the sunshade will get there easily, if at all. Even if it did, is it a good idea to have some water on the fabric that covers the sunshade from above??? I was thinking of siliconing it, but somebody suggested that it's there for a reason- to let a little water in and let it drain, which does not seem to make sense to me...
Anyone has any ideas? Should I silicone it? Or, if not, why?
Roman
Roman
i have that gap
the reason i have that gap is i had my sunroof repaired a while back b cuz it would slide back and forth n e more
since then they fixed it but htere is still a gap and it does leak.
NOTE THAT i didnt get the roof fixed at nissan
which i prob should have.
Re: i have that gap
