EVAP code will not go away...
Old Aug 8, 2006 | 03:55 PM
denami's Avatar
i have not been able to get my inspection for a few weeks now due to code 1008, i replaced the soleniod and canister in the rear of the car and checked every hose and checked the evap valve in the engine and the hoses there, nothing is clogged but yet the code keeps coming back on...the only diffrerence is that it used to come on after 3-5 miles of resetting the light, now i can go 50-60 miles before it comes back on, i am so sick of this problem haha i just want to put my new mods on i just bought y pipe and intake, but im waiting until i get my sticker to put them on. please anyone offer some sort of solution. thanks
Old Aug 8, 2006 | 04:23 PM
ddurandd's Avatar
I fixed my 1008 code back in May. Here's how I did it. I had to get a part from the junkyard, but I felt safe because I knew how to test it first. The part I fixed was in the engine bay.
http://forums.maxima.org/showthread....82#post4982382
Old Aug 8, 2006 | 05:02 PM
denami's Avatar
hm, i know nothing is clogged with that piece in the front, and i do not have an ohm reader but even if i did i would have no idea how to use it to check the harness....im sorta a newbie at that type of electrical work, can you give me some better instructions on how to test...i also have a 96 gle btw...thanks
Old Aug 8, 2006 | 05:58 PM
njmaxseltd's Avatar
Replace your gas cap. If it's leaking you'll throw EVAP codes all day long.
Old Aug 8, 2006 | 06:20 PM
denami's Avatar
yea ive heard of that also, but it doesnt seem to be leaking and it screws on tight, i dont get an evap leak code just that 1008 the purge valve canister.
Old Aug 8, 2006 | 06:38 PM
shadyonedeath's Avatar
ive got the same code poping up, along with 1005.
Keep me posted on your progress, i'd like to get it fixed too.
by the way, wheres the valve located?
Old Aug 8, 2006 | 07:03 PM
denami's Avatar
theres one on top of the intake manifold, 3 inches from the vin number stamped on the firewall, and the other soleniod/valve/canister is under the car behind the rear driver side tire, i replaced that canister valve and soleniod today but code is still coming up what a pain in the *** this is
Old Aug 8, 2006 | 07:21 PM
Ill take a look at it tomorrow in the morning.
Did you read about some valve peice being stuck and using wd-40 to get rid of the problem? Not sure if its the same part your talking about, but if it is, its worth a try.
Old Aug 9, 2006 | 02:40 AM
denami's Avatar
nope ive never heard of that, the only other valve im assuming i would have to replace would be the one on top of the intake manifold, but that one wasnt clogged at all.
Old Aug 9, 2006 | 12:16 PM
histo13's Avatar
1008 is canister purge volume control valve.I had that problem before and replaced cpvcvwith a used one and after 1k miles the cel came back. I opened the electrical connector with (with 3 philip screws).all wires inside were all rusted. I read it one time on this forum that a brand new cpvcv cost $140 .i just forgot where they bought it.I still have the same cel for almost 2 months now for I don't notice any diff. with regards to performance of my car
Here's the picture!http://smg.photobucket.com/albums/v1...gAnch=imgAnch2
maxinout93
Oct 31, 2015 02:04 AM
tseng1023
Oct 15, 2015 08:30 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
