So I got the PO325
Old Aug 8, 2006 | 08:54 PM
Cdg2125's Avatar
So I got the PO325
Yep I checked my codes today and I thought they would be my o2's...yeah apprently not. Now I gotta change the knock. So I was going to ebay for that $60 deal. Good quality correct? Also, I got a P1448 code as well. Aux Emissions Contrl. Will this code go out when the knock is fixed? Just wondering.
Old Aug 9, 2006 | 05:42 PM
bkmax96's Avatar
knock sensro is a biachhh
Old Aug 9, 2006 | 06:31 PM
Hondawhat?'s Avatar
the knock sensor is not that bad the p1448 I think has to do with the evap canister control valve but I will doudle check at work on thursday.
Old Aug 9, 2006 | 06:39 PM
96blkonblkse's Avatar
knock sensor isnt bad, ive got it down to an art, takes around 20 minutes...assuming the engine is cool
Old Aug 10, 2006 | 06:09 AM
Colonel's Avatar
Old Fuddy Duddy
The lady here has a knock sensor code on her 98se. How hard to replace? Is there a writeup somewhere? I have an 01 and done the O2's, which are also throwing codes on her car.
Advice on where to get the sensors and replacement? I am trying to help her save as much money as possible on it.
Thanks!
Colonel
EDIT: I found the information on removal and replacement. The search put it at the bottom, not the top where I was expecting it. DOH!
She put crap gas in. So I am going to have her run out the garbage gas, get a tank of happy gas and reset the computer after the tank of happy gas is gone. Off to search for the 4th gen ECu reset procedure.
Old Aug 10, 2006 | 10:12 AM
Hondawhat?'s Avatar
p1448 is the vent control valve there is a tsb where you have to replace the vent control valve and the canister in the back and add a water seperator have fun it is really pretty easy just call the dealer
Old Aug 13, 2006 | 10:44 AM
Cdg2125's Avatar
is the P1448 a big problem? Should I worry about it now or later? Obviously I'm doing the knock first.
kcsaarts
Aug 15, 2014 10:20 PM
nselca2
Jun 27, 2011 01:43 PM
slow_yota
Jun 27, 2011 09:36 AM
S1cTech
Apr 25, 2008 07:50 AM
torontoboy
Sep 4, 2002 08:05 PM
