Under the Flywheel ??
when does a thread get stickied or added to FAQ?
http://forums.maxima.org/showthread.php?t=440195
Jae
Jae
Originally Posted by i30ds
Matt,
You're using the Fidanza right? If you are, do not use this spacer.
What are tourqe specs of the flywheel bolts and the pressure plate bolts ?? The book for the flywheel bolts say 25-33 ft lbs, but someone the other day said 65-69 ft lbs.?
-matt
Yeah, no spacer with the Fidanza, I'm not running one on mine. I don't recall off the top of my head what the torque is for the flywheel, and a friend has my FSM right now, but 69-69 ft-lbs. sounds about right.
Now, for the pressure plate bolts I believe the FSM said 25-35 ft-lbs for those, BUT, that was for the stock flywheel which is not made of aluminum like the fidanza. The metal on the fidanza flywheel is VERY VERY tender. I used 20 ft-lbs on them to avoid stripping the threads out of the flywheel holes for the pressure plate (happened on two of my friends bolt holes on his stillen flywheel when he tried to do 35 ft-lbs.). 20 ft-lbs. is fine as long as you have equal torque on each bolt and you follow the tightening pattern... VERY important.
Anyone have any tips on aligning the clutch disc ?? This is the first time Im going a clutch and I wanna make sure I do it right.
Theres no direction on my Clutchnet for the "Flywheel Side"....I know there is a direction on my Exedy, but not on my clutchnet. What side goes what ?
Thanks in advance.
-matt
Thanks in advance.
-matt
Any advice
I dont know what way the Disk Goes. On my Exedy, it is labeled "flywheel side" Do I put the Beefier side of the Clutchnet Disk towards the flywheel ?? Theres a beefy side of the disk and a thin side...
-matt
-matt
KabirUTA13
19
Oct 17, 2015 02:15 AM
kenc15
Sep 25, 2015 06:38 AM
