Fuses ??????
Old Jun 24, 2001 | 01:24 PM
WAC's Avatar
WAC
I lost the fuse cover where the fuse diagram was. I know , not too smart. But I have a fuse out. I need help with locating a fuse.
The fuse that im trying to locate is the interior light fuse.
Are these mini fuses ?
Can someone please help me out ?????
Thanks !
Old Jun 24, 2001 | 01:42 PM
Kashoggio's Avatar
yes its the mini fuse
Old Jun 24, 2001 | 01:45 PM
WAC's Avatar
WAC
That's what I thought , and thanks.
But my real problem is which fuse is for the interior lights ???????
Old Jun 24, 2001 | 01:47 PM
Kashoggio's Avatar
ok, its a 7.5 amp fuse and its in the middle fuse column
its the 7th from the bottom
Old Jun 24, 2001 | 01:50 PM
WAC's Avatar
WAC
Kashoggio
Thank you soooo much. Now I can go pop that puppy in !
Old Jun 24, 2001 | 01:53 PM
Kashoggio's Avatar
no problem, glad i could help
Old Jun 24, 2001 | 02:06 PM
WAC's Avatar
WAC
Weird, I just replace the fuse and still no interior lights. The bulbs are all good. The old fuse looked fine. I just do not know what else to do. Anyone know of something else I can check ?
Old Jun 24, 2001 | 02:23 PM
Daniel B. Martin's Avatar
Thanks !
The passenger cabin fuse block is located behind a pull-out panel in the lower dashboard, to the left of the steering column. It has three columns of fuses.
Numbered from bottom to top....
- the left-hand column contains fuses 1 - 11
- the middle column contains fuses 12 - 26
- the right-hand column contains fuses 27 - 40
The numbers are molded into the plastic fuse block. They are not easy to read. A flashlight will be helpful.
The term "Interior Light" is ambiguous. Perhaps you mean the Dome Light. Check fuse #26 (7.5 amps).
Old Jun 24, 2001 | 02:34 PM
WAC's Avatar
WAC
Danial,
Thanks !
Now ALL the inerior lights work.
Old Jun 25, 2001 | 09:01 PM
Kashoggio's Avatar
well then dont I just suck
leatherneck
Sep 30, 2015 09:16 PM
Junebug1701
Sep 25, 2015 01:54 PM
conansriver
Sep 16, 2015 12:17 PM
jwright36
Sep 8, 2015 11:45 AM
