Cluster Needles Sticking; Need Help!!!asap
Old Aug 13, 2006 | 12:37 PM
khantalha+'s Avatar
MY buddy and i were working on my gauge cluster yesterday to put those glow gauges on, everything worked out great except for the RPM one. After putting everything back together, i took it for a test drive and found out that the TEMP. NEEDLE wont go over the first 1/4, RPM needle does work but shows little lower rpms i mean when idling it showed 400, and the gas needle feels a little heavy. I can fix the speed one but need some help fixing the other ones.
SO JUST NEED A LITTLE HELP!
" ---to you guyz"
Old Aug 13, 2006 | 12:39 PM
99se5speed's Avatar
SHIFT_up
you have to re-calibrate them...but i'm sorry i forgot how. Someone might step in and help.
Old Aug 13, 2006 | 12:40 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Seems as though you did not put it back in properly. I would take them out and give it another shot.
Old Aug 13, 2006 | 12:41 PM
I have the method on my homepage
Old Aug 13, 2006 | 12:47 PM
99se5speed's Avatar
SHIFT_up
^ Metal Maxima knows his **** about clusters!!! So khantalha read his homepage!!
Old Aug 13, 2006 | 12:55 PM
It's somewhere in here, I think
Old Aug 13, 2006 | 01:13 PM
khantalha+'s Avatar
THANKS GUYS
I just tried it but did not work and remember my cluster is not digital so is there any thing else i can try?
Old Aug 13, 2006 | 01:14 PM
Originally Posted by khantalha
THANKS GUYS
How did you remove the needles and put them back in? Pull or twist?
Old Aug 13, 2006 | 01:17 PM
khantalha+'s Avatar
a little bit of both but mostly pull, when i pulled the rpm one it came out with the pin that goes into a little motor.
Old Aug 13, 2006 | 01:25 PM
Ah, christ...you might have ruined the servo.
The only thing you can do is remove them and try again.
Old Aug 13, 2006 | 01:28 PM
khantalha+'s Avatar
yeahhhh, i was thinking the same thing, i ll go ahead and try it and see if it works, and let you know shortly!!!
But thanks anyways.
Old Aug 13, 2006 | 03:58 PM
khantalha+'s Avatar
i tried it again, had to take it apart. Took it for a test drive every thing works fine now but the needles on RPM and TEMP gauges still feel a little heavy, I mean when i turn it off they go down real slowly. SO is there any thing else or just leave em as they are. and one more thing, when i turned it off the rpm one stopped at about 200-300 rpm but as soon as i turned the key to ON it went back to where it should be..
captchaos
Mar 15, 2016 12:18 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Max139617
Sep 6, 2015 06:02 PM
