Lateral Link Hitting Sway BAr
Old Aug 14, 2006 | 05:39 PM
Wheelie King's Avatar
I have a progress rear anti-sway bar on my rear axle. My lateral link is traveling so far down that it is hitting the sway bar. I lowered the sway bar as much as possible but I'm still getting contact. It sounds bad and its actually denting the sway bar. Is there a way to limit the travel in the lateral link?
Any info will be appreciated.
Old Aug 14, 2006 | 05:46 PM
vsamoylov
thats alot of play in it. that link should barely move.
Old Aug 14, 2006 | 06:02 PM
Is this something that can be tightened or are they replaced when worn? I've never heard of any problems with them.
Old Aug 14, 2006 | 06:12 PM
vsamoylov
my bad you are talking about the lateral link. i thought you were talking about the bar that is inside the torsion beam.
the lateral link does come apart from the torsion beam. by looking at the fsm it looks like its bolted to the torsion beam with 2 nuts. i am assuming that the bushings inside of it are worn or cracked and there is excess play in them
Old Aug 14, 2006 | 10:39 PM
96i30azn's Avatar
I have one installed and can't imagine how anything can hit the bar. Got pics?
Old Aug 15, 2006 | 03:42 AM
I'll post pictures tonight.
Has anybody ever replaced the bushings in their lateral link? Did that cure excessive play?
Old Aug 15, 2006 | 03:54 AM
njmaxseltd's Avatar
I agree, something doesn't sound right.
There's no way that link can hit the sway bar.
Old Aug 15, 2006 | 07:36 AM
JPMax's Avatar
What's next!?..
need pics.. I just can't picture it..
Old Aug 15, 2006 | 07:38 AM
MaximaSE96's Avatar
Maxima Owner
are u sure u have it installed correctly
Old Aug 15, 2006 | 05:40 PM
Based on the response that the llateral link should never hit the sway bar, I did a little web surfing and found a good site for directions and pictures of a sway bar installation. It shows the bar attached underneath the axle. Foolishly, I placed mine in front of the axle underneath the lateral link. That explains the problem. I'll move it under the axle this weekend. I don't know why I thought it should be installed in front of the axle. I think I was trying to limit the profile of the bar and mounting hardware from the rear of the car. It was a while ago.
I'll attach a link to the website with good instructions and illustrations in case anyone needs them. http://forums.nicoclub.com/zerothread/157914
Thanks for the help.
Old Aug 15, 2006 | 09:45 PM
96i30azn's Avatar
That's why I couldn't figure you out . I was thinking "wouldnt the lateral link have to go through the beam to get to your sway bar?"
t6378tp
Sep 29, 2018 04:27 PM
captchaos
Mar 15, 2016 12:18 PM
Stagnet04
Sep 14, 2015 11:28 PM
minsbang
Sep 5, 2015 05:36 AM
