NOOBIES: The "I AM NEW HERE BUT HAVE A QUESTION" thread...
Old Feb 13, 2007 | 06:12 PM
  #721
Cdg2125's Avatar
Originally Posted by btvenom
I need help in deciding between, these two. If im not mistaken these two are CAI that involve cutting... a whole in my fender, which idk about yet but, i've seen some on Ebay but i dont trust ebay..
I just want the cheapest option for some more power.. I already love the power the car has, I think its plenty but having some more would be nice.:P im a little greedy..
http://www.procarparts.com/store-det...=onlinestoreDB $45.00
http://www.procarparts.com/store-det...=onlinestoreDB $74.99
I do need to solve the problems with my missfiring/ignition coils crap..
it's pissing me off latley but, im always thinking about putting a CAI on my maxima so, I wanna do it!.
Is this considered a HAI?
CAI links dont work. But the last link would be considered a HAI.
Old Feb 13, 2007 | 06:16 PM
  #722
btvenom's Avatar
Sorry here are the correct links, I did'nt copy them correctly
Old Feb 13, 2007 | 06:42 PM
  #723
Cdg2125's Avatar
I think they are both fine. The second one is just more expensive because you're getting the k&n filter with it.
Old Feb 13, 2007 | 08:19 PM
  #724
Flava_24/7's Avatar
Boosted Panda
That last one is just a short ram. An injen type of intake is a HAI because it relocates the piping but is still pulling in warmer air. The short ram just eliminates the air box. Granted, its still pulling in warm air from the engine bay, but the filter is not being relocated into a warmer area like behind the radiator.
That second intake would be the best bet considering its price, your paying mostly for the better filter.
Old Feb 13, 2007 | 09:07 PM
  #725
Cdg2125's Avatar
i knew it was a short ram, i just consider it a hai.
Old Feb 14, 2007 | 05:47 PM
  #726
qazplm1999's Avatar
I am trying to check yhe ECU for codes (CEL came up). I have 97 GLE and the cover for the ECU have two screws that have round smooth top (not phillips or flat). How can I remove the cover to access ECU?
Anyone knows? please help! Thank you.
Old Feb 14, 2007 | 05:48 PM
  #727
2da mizzax's Avatar
pull them right out.
Old Feb 14, 2007 | 05:52 PM
  #728
qazplm1999's Avatar
The screw head is tight against the cover. Should I pull the cover directly? 'cus it's hard to pull the edge of the screw heads.
  #729
JPMax's Avatar
What's next!?..
Just grab the cover and pull hard. Those are just push-in plastic screws.
Old Feb 14, 2007 | 05:54 PM
  #730
qazplm1999's Avatar
ok. I'll try. Thank you.
Old Feb 14, 2007 | 06:45 PM
  #731
qazplm1999's Avatar
I checked the ECU and pulled code 0101 and 0304. Do those codes (camshaft position sonsor and knock sensor) cause engine stall at red light or stop sign? I am trying to solve the stall first. I will clean the TB tomorrow morning and replace the ECTS. I got 0101 and 0304 after my car stalled this evening for about 30 minutes before I could start it again and drive home.
Old Feb 14, 2007 | 06:49 PM
  #732
2da mizzax's Avatar
why are you replacing the ECTS? And yes the Camshaft position sensor can cause stalls. the KS wont but should be changed anyhow.
Old Feb 14, 2007 | 06:56 PM
  #733
qazplm1999's Avatar
I searched the forum for similar problem and found that many are related to ECTS and my car won't start up after the stall. I suspect the ECTS is not functioning. I know my TB needs cleaning because it's been having low idle and the stall may be related to that too, but I am not sure why it won't start up right away.
Old Feb 15, 2007 | 03:00 AM
  #734
dgeesaman's Avatar
Maintenance Monster
If your idle dips and tends to stall, consider changing your fuel filter.
Old Feb 15, 2007 | 03:37 AM
  #735
qazplm1999's Avatar
thanks. I'll try that too.
Old Feb 15, 2007 | 02:18 PM
  #736
Jupak's Avatar
where can i find a new license plate mounting bracket for the front?
Old Feb 15, 2007 | 02:25 PM
  #737
bigpulve+'s Avatar
Any of the part outs in the the 4th gen classifieds.
http://forums.maxima.org/forumdisplay.php?f=61
Old Feb 15, 2007 | 04:39 PM
  #738
JPMax's Avatar
What's next!?..
You can also order online from places like: $25-35
www.autowarehouse.com
www.partstrain.com
Old Feb 15, 2007 | 05:52 PM
  #739
qazplm1999's Avatar
I have to ask you guys for more advice. I'd better tell the whole story. About 2 weeks ago, my car stalled at the red light with no code thrown, took it to dealer and they could't find anything wrong. After I picked up my car and drove back, I noticed when the engine got warm, the idle speed when at D with brake pressed went down to 600, and I can feel a "cough" symptom(vibration, misfire?). When I put it to Neutral or Park, the idle went up to 700 and smooth. The car stalled at red light and stop sign. Yesterday, when it stalled again, I got code 0101 and 0304. Today, I have the TB cleaned and fuel filter replaced, the low idle didn't get better and the "cough" like vibration still there and the car still stalls, and more often now. Maybe the vibration is caused by misfire because of the Camshaft Position Sensor (0101)? but that's not the cause of the low idle (600rpm at D), right?
My friend who did the fix for me today didn't have the gasket handy to clean IACV, maybe IACV is causing the low idle? He's a GM mechanic, should be qualified to clean those.
Any suggestion would be much appreciated!
Old Feb 15, 2007 | 05:57 PM
  #740
btvenom's Avatar
I have to ask you guys for more advice. I'd better tell the whole story. About 2 weeks ago, my car stalled at the red light with no code thrown, took it to dealer and they can't find anything wrong. After I picked up my car and drove back, I noticed when the engine got warm, the idle speed when at D with brake pressed went down to 600, and I can feel a "cough" symptom(vibration, misfire?). When I put it to Neutral or Park, the idle went up to 700 and smooth. The car stalled at red light and stop sign. Yesterday, when it stalled again, I got code 0101 and 0304. Today, I have the TB cleaned and fuel filter replaced, the low idle didn't get better and the "cough" like vibration still there and the car still stalls, and more often now. Maybe the vibration is caused by misfire because of the Camshaft Position Sensor (0101)? but that's not the cause of the low idle (600rpm at D), right?
It's your Ignition Coils, I had the exact same problem, you need to find out which one it is by taking them out (not hard if you need help PM or Email me) using a multimeter.
Old Feb 15, 2007 | 06:11 PM
  #741
qazplm1999's Avatar
Don't have right to PM yet. Sent you an email. Thank you.
Old Feb 15, 2007 | 06:15 PM
  #742
btvenom's Avatar
no problem, I got the email, please check the box to enable email from other users, i had to send you an email the hard way, instead of clicking a link :P
Old Feb 15, 2007 | 06:18 PM
  #743
qazplm1999's Avatar
I changed my settings. So much to learn here. :P
Old Feb 15, 2007 | 06:45 PM
  #744
qazplm1999's Avatar
Any more suggestions?
Old Feb 16, 2007 | 12:16 AM
  #745
maxforlife's Avatar
My CEL is on and I get codes 0102 (Mass Air Flow Sensor) and 0504 (Automatic Transmission Control Unit Signal to ECU).
What can I do to fix this?
I just reset the CEL for now and its off, how long before it comes back on?
Old Feb 16, 2007 | 08:34 AM
  #746
JPMax's Avatar
What's next!?..
I agree w btvenom.
Goin by your username, I assume you have a 99 model.
They were prone to having bad ignition coils.
Try checking those first.
new one at dealer will cost $80-100 each.
people usually have used ones available in the 4th gen forsale forum.
Old Feb 16, 2007 | 08:36 AM
  #747
JPMax's Avatar
What's next!?..
Try getting yourself a can of electronics cleaner spray and cleaning the MAF sensor. Make sure the connector plug for the MAF is clean too.
You can get the spray from Radio Shack or some auto parts stores.
Old Feb 17, 2007 | 10:17 AM
  #748
bpk01's Avatar
0503 0115 0304
I pulled 3 codes yesterday 0503, 0115, and 0304. Is it possible that the 0503 code for the front oxygen sensor is causing the 0115 code for the lean fuel mixture? Since i have to replace the knock sensor and an oxygen sensor is there a "best" brand?
Old Feb 17, 2007 | 01:50 PM
  #749
speed racer's Avatar
get a bosch universal oxygen sensor. This is a pretty descent site.
http://www.oxygensensorwholesale.com/
Old Feb 17, 2007 | 09:25 PM
  #750
JPMax's Avatar
What's next!?..
Replace the oxygen sensor first.
Then reset the ECU and see if the other 2 come back. They're usually caused by the bad O2 sensor.
and get the sensor with the oem plug. save you the trouble of splicing wires.
Old Feb 18, 2007 | 12:13 AM
  #751
bpk01's Avatar
I know NGK is good for spark plugs how about oxygen sensors? Thanks for the info.
Old Feb 18, 2007 | 05:55 AM
  #752
I'm not sure. I would heed the previous advise though about the oem plug. The last thing you want to do is change the wires b/c of the connector.
Old Feb 18, 2007 | 04:41 PM
  #753
JPMax's Avatar
What's next!?..
I believe Bosch makes the stock O2 sensors.
Old Feb 18, 2007 | 05:52 PM
  #754
Cdg2125's Avatar
I didn't want to start a thread so I figured post in the newb area. I have 6 plugs that I never used in my 91 max. 91 was also a 3.0. So will the plugs work since both engines are 3.0 DOHC? I don't feel like throwing them away for nothing.
Old Feb 19, 2007 | 08:57 AM
  #755
megamn44's Avatar
Hey guys, I've looked around threads and googl'ed this a hundred times and i haven't found an answer so i was hoping someone could help. I just recently installed the Pioneer DEH-P4900iB from Crutchfield. ( http://www.crutchfield.com/S-uZnutLK...130DEHP490#Tab ) I also bought the Scosche adapter b/c i have the Bose system in my car. I followed the directions and hooked up the entire thing myself. The stereo turns on, and the power antenna switch i installed myself even works great too, only problem is that everything works except my tweeters on the front pillars. Has anyone else had this problem, or anyone know how to fix this? It would be greatly appreciated.
Old Feb 19, 2007 | 09:02 AM
  #756
MDeezy's Avatar
I assume you mean spark plugs. which brand, which model/part # and what gap setting. the 91 max had a very different engine than the 3.0 you have in your 98. If anything make a for sale thread and sell them to another org member.
Old Feb 19, 2007 | 09:03 AM
  #757
MDeezy's Avatar
this is true.
Old Feb 19, 2007 | 09:29 AM
  #758
Cdg2125's Avatar
Thanks MDeezy. I don't know numbers or anything. They're at home in my garage so I guess I'll just try to sell them. They are platinums I believe, just more than a year old lol
Old Feb 19, 2007 | 07:43 PM
  #759
bpk01's Avatar
Thanks for the help I went by Autozone today and saw that they are about $83 + tax so I have to wait until payday on Thursday. They are the 3 wire ones correct?
Old Feb 20, 2007 | 02:58 AM
  #760
dgeesaman's Avatar
Maintenance Monster
I've used the Bosch universal sensors with good success, and saved a bunch of money too.
