NOOBIES: The "I AM NEW HERE BUT HAVE A QUESTION" thread...
Old Mar 9, 2007 | 05:51 AM
  #841
headhunt3r's Avatar
Homelink work for rolling code garages?
My garage door opener recently got replaced and this new one has a "rolling code". I've tried programming my Homelink accordingly but it doesn't seem to work. I'm wondering if it is compatible in the first place with this style of door openers. My Max is a 97 SE.
Old Mar 9, 2007 | 05:54 AM
  #842
phenryiv1's Avatar
Mod her. Ate her.
It is, but you have to use the rolling code programming instructions for the homelink transmitter. It took forever for me to get the '00 transmitter to work with my rolling code.
Old Mar 9, 2007 | 06:59 AM
  #843
JPMax's Avatar
What's next!?..
Originally Posted by asharma2377
Question for everybody... I have a 97 maxima GLE and it just started to shake intermittently when I drive. The biggest shaking occurrs around 50-60mph but the car does shake at lower speeds. The shaking lasts for a few minutes and then goes away and usually starts shaking slowly after I start the car.
Its not the alignment for when the car is shaking I can let go of the steering wheel and the car still goes straight. I dont think its my transmission for when the car is shaking I can still accelerate as normal. What i did notice is that when the car is shaking, I try to hit the brakes and its as if all i have to do is tap on the brake pedal to slow the car down whereas when the car is not shaking I would have to depress the brake pedal somewhat.
If anybody has any ideas on what the problem might be please do respond.
Thanks.
Does the car do this "shaking" when in park as well? If so, check all the ignition coils, clean the throttle body and MAF sensor.
If it only does it while moving, then check your brakes. Probably a warped rotor, rusted caliper slide pin, or faulty caliper piston.
Old Mar 9, 2007 | 11:59 AM
  #844
STILLENGLE's Avatar
Where Can i Find Private Profile Wheels?
Old Mar 9, 2007 | 08:09 PM
  #845
headhunt3r's Avatar
Ya... I've tried pretty much everything I could think of. Played with it for like over an hour and gave up. Was there any trick at the end that did the job for you? Any suggestions?
Old Mar 10, 2007 | 04:52 PM
  #846
phenryiv1's Avatar
Mod her. Ate her.
No. On try 5 or 6 it finally worked...but it un-programmed all of the other transmitters...
Old Mar 10, 2007 | 07:50 PM
  #847
bpk01's Avatar
thanks phenryiv1 I checked back and there was one posted today.
Old Mar 11, 2007 | 05:19 AM
  #848
dgeesaman's Avatar
Maintenance Monster
Pull the car in the garage so the visor is directly under the opener. Then open your moonroof if you have it.
I don't recall the exact sequence, but instead of programming it with an opener remote, you program it with the opener itself. Look in your owners manual and call Homelink's 800 number and they'll walk you thru it.
Dave
Old Mar 11, 2007 | 07:38 PM
  #849
ZachsMax's Avatar
Ridin' Spinnaz
Yeah, but sometimes I'll be driving and try to do it and it gets annoying. I mean, I don't think the car is supposed to do that. Does anybody know whats going on?
Originally Posted by dgeesaman
Use your keyfob to open the front windows before you get in. Just hold the unlock button for a couple seconds.
Dave
Originally Posted by Zach
Here's an interesting one..
I have a 1997 Nissan Maxima GXE. Whenever I'm holding down all four window switches and the sunroof switch at the same time (to open all windows and the sunroof simultaneously), I hear a clicking noise in the dash somewhere and none of the windows/sunroof continue to roll up or down. After about 2 seconds, I hear the same clicking noise and everything works again.
I don't have the problem if I roll only 2 windows up or down at the same time, but if I try to do everything at once, it seems to overload everything. It gets kinda annoying...I live in Florida and must open all the windows/sunroof every time I get in the car to get the heat out!
Any thoughts? Thanks!!
Old Mar 11, 2007 | 10:25 PM
  #850
bpk01's Avatar
Oxygen Sensor
I just installed an oxygen sensor but didnt bother with clipping the wire holders in. Should i go back and snap them in or will it be ok?
Old Mar 12, 2007 | 05:22 PM
  #851
Deltaq's Avatar
Hey folks, New owner of a 96 maxima here w198k miles in need of some maintance and since im no mechanic, i ran into a problem on the rear driver side caliper piston refusing to retract inside the caliper using c-clamp to install the new brake pads.
I also noticed the rubber seal is torn and the piston shows signs of rust build up on the cylinder, will it be possible to rebuild the caliper or do i have to replace the entire caliper?
Only refference i've had so far is the Hayes service manual and memory of some eps i watch on powerblock shows on spike TV .
Any links/info would be greatly appreciated.
Old Mar 12, 2007 | 05:24 PM
  #852
2da mizzax's Avatar
rear calipers turn in. they dont push in witha C clamp. If your passenger side went in the the C Clamp then that one is the problem. not the other side.
Old Mar 12, 2007 | 05:30 PM
  #853
Deltaq's Avatar
Oh my, no wonder i count push it in after a certain point, will i have to buy a new tool to screw it in? i havent touched the passanger side, only serviced the front axles so far.
Old Mar 12, 2007 | 05:35 PM
  #854
2da mizzax's Avatar
one of these
prob about $10 at pepboys.
Old Mar 12, 2007 | 06:04 PM
  #855
Deltaq's Avatar
Cool, Local shops r closed at this hour, will have to resume tomorrow ^^
Since the rubber boot of the piston is torn will the piston need to be replaced aswell or will it depend on how funtional i will find the caliper?
I found a caliper kit that includes the seals and piston for 5 bux at advanced auto parts but its mail in only.
Tru Torque Brake Caliper Kit
Part Number: D352027
Old Mar 12, 2007 | 06:09 PM
  #856
2da mizzax's Avatar
That is your call. If you feel confident enough to "rebuild" the caliper then go for it. I would wait to see if it is seizzed first however since there is a chance it may have to be replaced.
Old Mar 13, 2007 | 05:41 AM
  #857
Deltaq's Avatar
Went to the shop today for the part, tried to turn it with the wrench and no cigars. Guess its seiged since it only managed to move when i started using the impact wrench.
Further instection i found another problem, the guide pin that resides on the caliper braket is stuck aswell.
Is the braket/pin salvagable or will i have to replace those aswell?
I lubed the pin with 3in1 oil to see if i can get this thing loose but its hard on that i can barely nudge it with clamp pliers.
Edit: typos
Old Mar 13, 2007 | 06:52 AM
  #858
phenryiv1's Avatar
Mod her. Ate her.
NOTE: This thread is winding to a close. Effective Fri, March 9, 2007, this thread will be locked!
HOWEVER, I WILL be opening a NEW thread. This one has gotten too long to monitor easily.
Time limit extended.
Old Mar 13, 2007 | 06:58 AM
  #859
2da mizzax's Avatar
Edit: typos
New bracket and guide pins. Even if you get the old one out and loose, the gap will be so close that it will most likely seize up again.
Old Mar 13, 2007 | 04:33 PM
  #860
jpm36's Avatar
Front Speakers
I just have a real simple question to ask pertaining to replacing my front speakers. I have a 96 GXE non Bose, and was wondering how i go about changing the front door speakers. Do the speaker covers pop off or do I have to remove the door panel? If I have to take the panels off, are there any instructions wandering around that would guide me through the process? Thanks in advance for any help you give, and please forgive me for my "newbness" in regards to this audio question.
Old Mar 13, 2007 | 04:34 PM
  #861
andrei3333's Avatar
the door panels come off
Old Mar 13, 2007 | 04:43 PM
  #862
jpm36's Avatar
I apologize for wasting peoples time, I managed to find instructions. Regardless, thanks for the quick response.
Old Mar 14, 2007 | 06:35 AM
  #863
nicki's Avatar
help, solenoids explanation
so my engine light has been on, 4 codes. one is a transmission code. i took the car to the dealer so they can run the tests. they had to drop the transmission pan to see what the problem was for the code P1760. they told me i had to have the solenoids replaced. i don't know much about all this except that they deal with shifting right? the dealer wasn't much help. i've had this code for months & my car has never given me any problems. til i was driving my car home from the dealer. the car/transmission was jerking terribly. i had to pull over twice. ended up putting the car in 2nd & driving home with the flashers on. called the dealer back & told them what happened. all they said was it's the solenoids acting up that need replaced. am i being fed BS? can someone please explain this a little better to me?
thank you in advance.
(i ended up having the car towed to a transmission shop, haven't heard anything yet)
Old Mar 14, 2007 | 02:07 PM
  #864
Cdg2125's Avatar
what are the other codes? Sounds like your solenoids are messed up. The idea is that the solenoids go on and off to shift the tranny. Don't remeber what the combos are at this exact time but if one is working it will mess up the tranny gears. Probably the problem but telling the other codes could help diagnose.
Old Mar 14, 2007 | 03:30 PM
  #865
nicki's Avatar
well i found out earlier that it's the torque converter that is bad which i guess caused the solenoids to go. so the transmission needs rebuilt. it will cost about $1500.
the other codes P0440 (replace vent valve & canister) i heard there was a 'recall' on this but for whatever reason my vin doesn't fall under that.
P0400 (clean out the egr tube & components, replace gasket)
there was knock sensor code but i was told to ignore since it could've come on from one of the codes above.
all this & the inspection is up at the end of the month.
when it rains it pours.
i currently have about 94k miles on the car. i'm hoping it's gonna go for a long time now. i hate to see go down hill from here.
Old Mar 15, 2007 | 01:11 PM
  #866
Hondawhat?'s Avatar
Im not sure if this question has been asked in this thread yet but Im not going to read through all 29 pages.
Is it possible to add the auto sportshift to 98 maxima. If so would it be costeffective I like auto but sometimes I want to shift I have never seen it done so it might not be worth it but I would like to know if it is possible
Old Mar 15, 2007 | 01:12 PM
  #867
Hondawhat?'s Avatar
Sorry another Quick Question How do I find out about VA area maxima meetings?
Old Mar 15, 2007 | 02:16 PM
  #868
Cdg2125's Avatar
Yeah fix the other codes and the KS code should go away. If it doesnt then you may need to replace it. 94k...you have plenty of life left in the car if you take care of it.
Old Mar 15, 2007 | 02:21 PM
  #869
Cdg2125's Avatar
There was something made that Slimer is selling on here. Its manumatic system that takes over the CC buttons and you shift up and down with them. There was also a shift_fast mod created using a switch to control solenoids for the tranny for 1-3. 4th is a harder story to get but the point of the shift_fast mod was for track and nobody used 4th at the track. I started a thread in the All motor forum on an idea I had with a push button shift_fast. It's still being worked on since 4th gear is a b!tch to get the shift. 1-3 work according to the guys that got to wire it up and they are improving on it still. This is not an easy mod and if you no nothing about wiring or how the tranny shifts, don't touch it. If you want to shift then shift from 1-2-D if you feel like it.
Do a google search on VA maximas. Not hard.
Old Mar 15, 2007 | 05:07 PM
  #870
atamai5's Avatar
transmission problems
A night before i dissconected a fuse called A/T Cont because i need these fuse for the T.lights. On the morning i drive my maxima and i notice that the Overdrive button did not work, and i cant acelerate over 2K, the car loose power.
The car throw me codes:
0304 Knock Sensor
0504 Automatic Transmission Communications line
0804 Transmission Control Module
I had a problems before with the battery, i think probably i have a short circuit, because the battery gets drain on the nigth.
Any idea please?
Old Mar 15, 2007 | 05:19 PM
  #871
2da mizzax's Avatar
lets see. you take out the transmission fuse, then get 2 transmission codes. and you are asking for ideas?
Old Mar 16, 2007 | 07:42 PM
  #872
qazplm1999's Avatar
My max's having click noise from rear left wheel, and when I jack the car up and try to spin the wheel by hand, I can feel friction, not spin freely. Does this mean the brake rotor is warped? Thank you.
Old Mar 16, 2007 | 08:07 PM
  #873
shellymac's Avatar
Girl trying to fix a starter?
I am replacing my starter and need to know where the bolts are located to take the starter off the engine? i have already taken the bottom right one off, but need to know......... is the top one smaller? cause i see three bolts.
Thanks!!!!
Old Mar 16, 2007 | 08:13 PM
  #874
Fr33way™'s Avatar
Wild for Width
Starter is held with two bolts.
Old Mar 16, 2007 | 08:18 PM
  #875
maxima985spd
the top one is smaller. Technically there are three bolts. one also hold the power wire onto it. the smaller mounting bolt is directly above to the left of power wire nut.
Old Mar 16, 2007 | 08:48 PM
  #876
shellymac's Avatar
That's good cause that's the one i am working on, just don't know how to get any leverage with that bolt? also, seems like my ratchet is having a hard time fitting in that small space? any ideas? cause on the other one i got leverage with a breaker bar + a small pipe.
Old Mar 17, 2007 | 04:44 AM
  #877
2da mizzax's Avatar
It means your wheels bearings are shot. that or your rear pads are completely gone and you are scraping the rotors (which you should be able to see).
Old Mar 17, 2007 | 04:55 AM
  #878
dgeesaman's Avatar
Maintenance Monster
You should feel friction from the brake pads dragging a little bit.
Try to twist the wheel (pull on the top of the wheel and push on the bottom). Do it in several directions. If there is any play then the wheel bearing is shot.
Or just take it to a mechanic for diagnosis.
Old Mar 17, 2007 | 04:57 AM
  #879
dgeesaman's Avatar
Maintenance Monster
The rear starter bolt is a little hard to reach - I use a deep socket + 3" extension. My wrench then just fits between the starter and motor mount.
Wear heavy leather gloves so yo can put some uumph into it without risking a major laceration.
Dave
Old Mar 17, 2007 | 08:54 AM
  #880
shellymac's Avatar
i don't have any deep sockets
never knew?
