5th Gen Clutch
Old Aug 21, 2006 | 08:23 AM
Pieps's Avatar
5th Gen Clutch
I know that there is no kit for buying the 5th gen clutch, but that you have to order it seperately. I have been told that everythingnissan.com is a good place to order it, but i still need to know a few things. I know that i have to order a new disc, pressure plate, and slave cylinder cause mine is shot. I need a new TO bearing, but what is that called on the website, cause i can't seem to find it? Also, what else is needed?
Another question that is related is about the y-pipe. I am goin to order the Warpspeed, but i have heard that you need new gaskets, such as crush ring gaskets. Where can i get those, or do those come in the package? Final question, would it be easier to install the y-pipe while changing my clutch, or to do it after everything is re-assembled?
Thanks for all the help
Old Aug 21, 2006 | 08:46 AM
NewEngSurf's Avatar
Just go to ur local nissan dealer, i got everything from coastal nissan in norwell MA, 5th gen pressure plate, disc, throwout bearing, slave cylinder and master cylinder all for about $330
Old Aug 21, 2006 | 08:59 AM
nismos14's Avatar
§è~® f®ÈÄk
Throwout bearing is also know as a release bearing. $330 for all that ? You got raped. You should be able to get all he parts for roughly $230 shipped.
Old Aug 21, 2006 | 01:25 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
do your ypipe when you do your clutch. it makes taking out the passenger side axle much easier.
Old Aug 21, 2006 | 02:50 PM
MDeezy's Avatar
Thats all thats needed
PP
Clutch disc
Slave cyclinder (since yours is shot)
Throw out bearing.
clutch alignment tool if they have one and will throw it in
That stock Y is so f*king big it just makes you mad.
Old Aug 22, 2006 | 06:11 AM
Pieps's Avatar
Thanks for all the help, but what about the gaskets?
Old Aug 22, 2006 | 06:40 AM
Majestic's Avatar
Yahhhhhhh
Damn man $330. Royally raped. I called everything nissan. Don't have the number. I can't even remember the guys name but it's always floating around the org. I did the 5th gen clutch in mine and I paid less than $200 for the clutch, TO bearing, and pressure plate. Dirt cheap, original and great quality.
Old Aug 22, 2006 | 09:51 AM
swmtam's Avatar
I think he mentioned that $330 was including the master and slave cylinders too, in addition to the typical clutch replacement components.
Old Aug 22, 2006 | 09:53 AM
Majestic's Avatar
Yahhhhhhh
o i c....the guy's name was Dave B.....now i remember
Old Aug 22, 2006 | 02:30 PM
i30ds's Avatar
Armed and Dangerous
The part numbers are in an ALL MOTOR sticky. Use those numbers and call everythingnissan to order to get the discount... pretty simple.
MAXSE5SPD
Sep 17, 2022 04:00 AM
BkGreen97
Apr 2, 2016 05:47 AM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
