MSD Digital Window Switch installation questions!
First, let me say that this is a duplicate post as I wasn't sure where to best post it (it's also in the "All Motor" forum).
Hey guys. I've never installed one of these b4. Here are my questions:
#1) What should I use for a 12V switched source? And where, exactly, is it located?
#2) What should I use for RPM signal input? Again...where?
#3) There are two other wires...one gray and one yellow. Gray is "normally closed. This wire will remove the ground source at your desired On rpm, and complete the ground circuit at the set Off rpm", and Yellow is "normally open. This wire will provide a ground source at your desired On rpm, and remove the ground at the set Off rpm". Which do I use?
Thanks very much!
Thanks very much!
vingodine
45
May 21, 2016 12:46 PM
shaunkey1
Aug 18, 2015 10:09 PM
kjm900r
Aug 5, 2015 07:14 AM
