can the jwt ecu....
The JWT is a modification of your stock ecu. So I'm not too clear on the question.
you can use a z32 Maff and bigger injectors, inform them of this and adjustments can be made. But you'll need to run some boost to top out the stock Maf.
Too vague.......need...........more.........info.
Seems as if you're asking if the JWT reprogram can be used with stock injectors/MAF.. Yes it can (N/A) With boost apps, you can use the JWT reprogram for F/I with a 370cc/Z32 MAF program.
For example at a give air volume the stock unit would send 5 volts to the stock injectors, where as the z32 mas would only send maybe 3 volts to the bigger injectors thus the same amount of fuel is sent. therefore with no boost it would never max out the larger injectors
First off 370cc injectors and a Z32 MAF are not needed at all for anything NA unless you are doing something spectacular and are maxing either of them out (highly unlikely). If the JWT ECU is programmed for 370cc/Z32 then yes it will run, but it will probably not be as powerful as the NA, stock injector/MAF program since the FI program is for boost and is not tuned as aggressively.
A JWT ECU is a good NA mod for just your basic gains without wiring or tuning, but if you are boosted then go ahead and get the EMU. IF you want to start looking at record breaking NA times then EMU is also a better idea than JWT.
litch
123
Jan 4, 2024 07:01 PM
t6378tp
Sep 29, 2018 04:27 PM
Mahmuth
Sep 25, 2015 10:08 AM
