Idle problem?
Old Aug 23, 2006 | 09:24 PM
QuiksilverMusic's Avatar
Idle problem?
Hey guys, so i dont know if you would consider this during idle or what, help me out. When im sitting at a red light, sometimes my rpms jump up and down from 500 to 1000? does that make sense? I just noticed it the other day, i thought maybe i wasnt keeping my foot on the break hard enough and they were slipping a little bit (cuz my pads are worn down and need to be replaced) but today it happened again, and i was definately holding down the break. Let me know if this doesnt make sense, and if it does what you make of it.
Old Aug 23, 2006 | 09:55 PM
nguyen925's Avatar
it has nothing to do with the brakes. im not sure what exactly could be the cause because i have limited knowledge in these areas. if anything it might be an ECU problem?
Old Aug 23, 2006 | 10:00 PM
I just sifted through more threads trying to find something, and it seems like it could be a couple things. knock sensor/temp sensor? ill take a look tomorrow morning before i head out and make sure all looks good.
Old Aug 24, 2006 | 08:03 AM
99grnmaxgxe's Avatar
Maybe a TPS sensor, that happened to me too. Do you have any codes popping?
Old Aug 24, 2006 | 03:21 PM
I have no idea, ive never looked before. haha, id still consider myself a newbie to a lot of stuff. My engine light tends to turn on and off at will, so im sure theres probably at least a code comin up. Ill try and check it later on, i think i remember seeing a thread that said the ecu is to the right of the gas peddle under the dash sorta?
97_GXE
20
Sep 17, 2015 08:12 PM
lrb6805
Sep 17, 2015 04:49 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
