Taking out rear/back window
Old Aug 29, 2006 | 11:12 PM
Fre$h_TurK
Searched but couldnt find... i already know its hard..should be professionaly done..blah blah..but can i do it with any tools?..then put it to an another car
Old Aug 29, 2006 | 11:22 PM
VIP Maxima
sikhtir .............
Old Aug 29, 2006 | 11:59 PM
Godson's Avatar
by no means am I an auto glass expert but..... I wouldnt. Probably a pain in the *** and glass shops are usually pretty cheap in my experiance. Some douche smashed my pass. side rear window,cost me 60 bucks installed and never had any problems,I would at least get a couple prices first,probably worth it
Old Aug 30, 2006 | 02:41 AM
Fre$h_TurK
ur very good
Old Aug 30, 2006 | 02:42 AM
Fre$h_TurK
i'll do that today ..go around..
Old Aug 30, 2006 | 06:49 AM
nismos14's Avatar
§è~® f®ÈÄk
Is your's busted?
Old Aug 30, 2006 | 07:09 AM
Fre$h_TurK
Originally Posted by nismos14
Is your's busted?
no sir.. i bought a max with tints on it except the passenger side..i wanted to swap with mine...if possible
Old Aug 30, 2006 | 07:21 AM
95mtlMAXSE's Avatar
shift_Puff
just get a tint job done
Old Aug 30, 2006 | 07:31 AM
nismos14's Avatar
§è~® f®ÈÄk
Wait wait... so what exactly are you trying to do? I'm confused.
You have tints on the driver side of the car? But you wanna add that to the passenger side? Tint job would be MUCH less of a hassle then what you're trying to do.
Old Aug 30, 2006 | 07:44 AM
Dubbya's Avatar
VK56 Inside
You want to replace the rear window with one thats tinted??? The rear window is urethaned in. You would be much better off just getting your rear window tinted.
Now if you are talking about the windows in the doors, that is a completely different story. Those are easy to take out. Roll the window all the way down. Remove the door panel. Remove the window rubber gasket(the rubber that the window rolls up into). Then remove the 2 10mm bolts that hold the window in at the bottom. Then install the new window. 45 minutes tops.
For the 1/4 window in the rear door you need to unbolt the window support bar. There is 1 or 2 10mm bolts behind the door card and one phillips head screw behind the door weather stripping on the door. After that the 1/4 window just comes right out.
jsmith24
Feb 1, 2016 12:35 AM
Krazzespiinz
Sep 13, 2015 07:10 AM
markevans999
Sep 10, 2015 04:29 PM
ef9
Sep 5, 2015 11:18 PM
