Fianal Question about de-k swap what sensors
Ok I need to know what sensors must be swaped to make it work in a 95 max? SOme org members say some sensors and some say others and some say all. So witch ones is it. And what sensors will not be used from the dek?
God a good pic of the vacum lines would be great!
Just go by what I told ya about the Sensors. Bellhousing keek your DE, Cam on the timing case keep your DE. Your ref sensor by the pulley can be your DEK I believe. Im using it with no problem.
The FSM has some great pictures of the Vaccum Gallies that are on the 4th gen. I modified the bracket to mount onto the DEK Coolant log because it was ALOT easier then making your own bracket and then running a bunch of vaccum lines all over the place. The stock 4th gen gallies are nice and metal and clean looking after its mounted.
-matt
-matt
doobadoo
Aug 15, 2015 06:43 PM
