E Brake
Old Sep 5, 2006 | 05:21 PM
valvestud's Avatar
E Brake
hi guys my brake light keeps coming on and im not sure why. it goes off and then comes on again and really doesnt have any consistency. whats up? could it be that my brakes are needing replacement or what? oh yea and for all the smart asses yes the handle is down.
Old Sep 5, 2006 | 05:32 PM
NmexMAX's Avatar
dot dot dot ...
Brake fluid might be low, check it.
If it is, more than likely you'll need new pads soon.
Old Sep 5, 2006 | 05:38 PM
FormorAccordMan's Avatar
My brake light was on and my rear caliper was leaking fluid, so I needed to replace it. It can happen from the fluid being too low. go check it out.
Old Sep 5, 2006 | 06:09 PM
valvestud's Avatar
its so weird. any other ideas guys?
Old Sep 5, 2006 | 07:27 PM
NmexMAX's Avatar
dot dot dot ...
Did you check your brake fluid?
Old Sep 5, 2006 | 07:37 PM
99grnmaxgxe's Avatar
Come down to my house and I'll check it for you.
Old Sep 5, 2006 | 07:43 PM
valvestud's Avatar
well i checked it and its not below the minimum line. any thoughts?
Old Sep 6, 2006 | 03:30 PM
dabooki's Avatar
my brake light was just on, after a couple days i checked the fluid and it was just above the minimum line. i added a lil fluid to bring it up to the middle and the light went off.
Old Sep 6, 2006 | 03:41 PM
Solves your problems.
Old Sep 6, 2006 | 03:57 PM
super6's Avatar
check the arms that hold the e-brake lines on the rear calipers, it may be getting stuck, if so just clean it up with wd40.
Old Sep 6, 2006 | 10:33 PM
Brianne82's Avatar
Mine did the same thing but when my brake like came on so did my air bag light. Did this for about 2 weeks then its never done it again.. I figured it was a short somewhere.
Old Sep 7, 2006 | 04:55 PM
RedfoxXx's Avatar
it could be the PARKIGN BRAKE sensor, but it will also go off if the fluid presser drops
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
