tierod question(s)
Old Sep 7, 2006 | 12:21 PM
willard00's Avatar
tierod question(s)
so got some tires at sullivan tire and they told me to check my tierods. so i just have a couple questions:
1. what exactly do they do(something with alignment right?)?
2. how do i tell if they are bad?
3. how much do they cost?
4. how easy are they to replace?
Old Sep 7, 2006 | 12:53 PM
lophix's Avatar
They are one of the reasons you can control your wheels (left right turning movement) Difficulty scale: 1.5 out of 5, 5 being hardest (think tranny replacement being 5 and oil change being 1)
They should be about $40 each from your local parts store (autozone/oreilly/advance autoparts)
Symptoms? um...hmm...can't recall off the top of my head.
Old Sep 7, 2006 | 01:06 PM
willard00's Avatar
ok thanks, but besides symptoms...could you tell by just lookin at them? cause i mean, all they did was drive it in and back it out...so they must have looked at them and seen they need replacement?
Old Sep 7, 2006 | 01:26 PM
dgeesaman's Avatar
Maintenance Monster
Tie rods are the things that connect your steering rack the the wheels. These rods push/pull the wheels sideways to make them turn. When they go bad, there is a little play (wiggle room) when you turn the steering wheel but the resulting steering response isn't quite the same.
Well if you have an experienced eye and drive a lot of cars you may notice extra play in the steering wheel, or they may have felt some play when handling the wheels and hubs.
Outer tie rods are easy to replace. Inner tie rods are just a little harder than outers, but still pretty easy. Inners require a special wrench to change them while on the car. You will need an alignment after replacing any tie rods, and you should make an effort to make them the same exact length they were before you removed them, so that you don't kill your tires on your way to the alignment shop.
Dave
Old Sep 7, 2006 | 03:12 PM
willard00's Avatar
ok cool, ide be doing them at my school, so it would be like...off the lift, back up onto alignment rack. thanks for the help.
Old Sep 8, 2006 | 08:01 PM
jasonv's Avatar
jack your car up and shake your wheel side to side. if you feel play you need tie rods. have somebody pull down on the outer tie rod. if the play goes away you need outers. do the same with the inners.
Old Sep 9, 2006 | 03:57 AM
willard00's Avatar
side to side meaning left or right or in and out?
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
