Do You Have To Gap The NGK V-Power Copper Plugs ?
Old Sep 11, 2006 | 09:32 PM
matrix11229's Avatar
The NGK V-power copper plugs (BKR5E-11) are very cheap, and I heard they give a better spark than the platinum. I have no problems changing them every 20k-30k.
The only thing is that they require gapping(according to Strauss instructions).
Did anyone put them in without gapping ?
Are the V-Power plugs from Strauss and the Dealership the same ? (it's the same model number everywhere BKR5E-11) and is the factory preset gap the same ?
Old Sep 11, 2006 | 09:35 PM
konak85's Avatar
gapping is no big deal at all, takes 2 minutes to do all of them. Pick up a plug gapper from strauss for $.99 and gap them to .043. Its simple, you'll see what i mean
http://shop.com.edgesuite.net/ccimg....s/17011704.jpg
Old Sep 11, 2006 | 09:36 PM
Nissan 6's Avatar
yes you have to gap to .044
Old Sep 11, 2006 | 09:40 PM
Where can I find instructions ? How is the fuel efficiency with the coppers ?
Old Sep 11, 2006 | 09:42 PM
Nissan 6's Avatar
instrutions for what?
Old Sep 11, 2006 | 09:44 PM
Instructions how to gap them
Old Sep 11, 2006 | 09:54 PM
Nissan 6's Avatar
its not that hard, slide the gapper it between the electrode point and the tab and just turn the ring to the appriorite number.
Old Sep 11, 2006 | 10:03 PM
Thanks , I'm gonna try it. I heard NGK's come pre gapped at, or very near, the required spec. What was the factory preset gap on your plugs ?
Old Sep 11, 2006 | 10:51 PM
fernan198's Avatar
factory spec is .044
Old Sep 12, 2006 | 05:00 AM
DragonMaxima's Avatar
According to NGK's website it's already gapped at 0.044
Old Sep 12, 2006 | 07:26 AM
Conclusion: We don't have to gap the V-Power plugs since the NGK Platinums and Iridiums that don't require gapping have the same factory set gap of 0.044 as the V-Power.
Did anyone get V-Power plugs that had a different gap other than 0.044 ?
Old Sep 12, 2006 | 07:45 AM
NmexMAX's Avatar
dot dot dot ...
Of all the sets I've ever bought I never have gapped them.
Probably a good idea, but you asked if you had to, and I say no.
If the part # is different well then probably .... yes.
Old Sep 12, 2006 | 02:05 PM
konak85's Avatar
wtf is the big deal. just gap the biches
Old Sep 12, 2006 | 04:12 PM
p00tan6's Avatar
ahah , yes. The tool is $1.50. Do it and sleep better at night.
Old Sep 13, 2006 | 07:03 PM
I went to Strauss today and bought NGK V-Power plugs (1.99 each).
I checked the factory set gap and it was 0.032.
The 0.044 gap that NGK website shows is the gap that you should set for your Maxima. Every car needs a different gap.
You should gap all spark plugs according to your car manufacturer's specifications because the plugs are not gapped spesifically for your car(besides the ones that you buy at Nissan stealership).
Old Sep 13, 2006 | 07:08 PM
Tatanko's Avatar
Bacon Lover
I used them specific to the VQ30DE and didn't gap them, they were pre-gapped.
Old Sep 13, 2006 | 07:12 PM
Nealoc187's Avatar
SLOW
-11 in the part number is the gap. but it's not a bad idea to check them yourself.
Old Sep 14, 2006 | 09:26 AM
zippyflu's Avatar
can you guys really tell the difference in the platinum g-power and the regular v-power?
Old Sep 14, 2006 | 10:22 AM
Bobo's Avatar
The platinum g-power plugs are the wrong plug to use. Stick with the laser platinum OEM plugs or the v-power coppers.
Old Sep 14, 2006 | 11:11 AM
Zeppelin340's Avatar
Why is that? I just bought G - Power plugs and have yet to install them.. is there any reason i shouldn't install them?
Old Sep 14, 2006 | 12:12 PM
Bobo's Avatar
I have already stated the reason: they are the wrong plugs to use.
Old Sep 14, 2006 | 03:35 PM
maximan57's Avatar
They're fine to use in the Maxima. Check the NGK website, they say it's a recommended plug as well as the others.
Performs as well as the laser plats they just don't hold up as long.
Old Sep 14, 2006 | 03:40 PM
maximan57's Avatar
The only reason not to is if you're expecting them to go 60,000. They're rated for more like 30,000.
I've had them in my max for a couple of months and they're great.
Old Sep 14, 2006 | 03:53 PM
MadMaxSE-L's Avatar
Doggah Bite...
it's just a good idea to gap new plugs if only for the reason that they could have been dropped b4 you got them or something stupid like that and it only takes a second...
trsandrew
Apr 8, 2016 06:45 PM
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
