suspention questions?
Old Sep 14, 2006 | 10:56 AM
mindlessoath's Avatar
going to buy some struts, i want to know some information.
A.
Which one?
1. KYB AGX
2. Tokico Illuminas
B.
i think the KYB is more popular, but the other is less harsh, let me know your opinions.
the kyb has a ***, the other a screw driver, but can they both be adjusted easy? without taking things appart or modifying?
C.
the kyb is had for about 120$ a peice, and the Illuminas is had for about 150$ plus (probably about 160$), anyone have any other prices they have found?
D.
WHERE TO BUY? i need to buy these and buy them cheap, but from a good place. im not going to buy from ebay tho.
Old Sep 15, 2006 | 04:47 PM
jasonv's Avatar
just get them from ebay and be done with it
Old Sep 15, 2006 | 05:08 PM
Gismo-T's Avatar
B!tch We Got a Problem
Tokico Illumina
PerformancePeddler.com, need to log in Maxima.
1-800-470-1443
$408 shipped
Old Sep 15, 2006 | 05:24 PM
Cdg2125's Avatar
yeah dont go to ebay for suspension.....not a smart idea. Performance peddler has them and the group deal on the org has them. I think they are both 408 for the set.
Old Sep 15, 2006 | 05:47 PM
Gismo-T's Avatar
PerformancePeddeler: $408
Group Deal: $483
Old Sep 15, 2006 | 06:10 PM
Cdg2125's Avatar
Thanks Geo, appreciate the correction.
Old Sep 15, 2006 | 06:12 PM
Gismo-T's Avatar
No problem
Old Sep 15, 2006 | 08:58 PM
matts95max's Avatar
How about posting this in the forum specifically for SUSPENSION...
Old Sep 18, 2006 | 05:44 AM
anyone have thoughts on the other stuff i posted about?
Old Sep 18, 2006 | 06:35 AM
MaximaSE96's Avatar
Maxima Owner
Koni Sports aka Koni Yellows....but of waht u posted Illuminas......check the group buy...if not u can usually get a decetn price on eBay...KYBs are a lil more harsh on the softer settings...if that made sense...i think you will get more longevity out of the Illunimas...are u plan on changing springs too......also take it from someone who has put 3 suspensions and prolly a 4th...and learned some valuable lessons.....dont skimp out...spend an extra 50 or so dollars if u have too
Old Sep 18, 2006 | 07:08 AM
RA030726's Avatar
I'm nutty for Nissans
Just answer this
KYB AGX, cheap and harsh
Tokico Illuminas, more money and less harsh
Koni Yellows, most money, best performing, and still very comfortable
What do you want?
BTW front AGX & Ill. use a screwdriver, rear agx have a **** outside the trunk, rear Ill. use a screw driver in the trunk, koni fronts have a removeable **** but rears can only be adjusted off the car.
Old Sep 18, 2006 | 07:09 AM
MaximaSE96's Avatar
Maxima Owner
thats the only poopy part of the Yellow are the rears....but if u find the perfect settingu never have to change them
Old Sep 18, 2006 | 08:33 AM
i was reading the maxmods and some version of koni's have the car modified. is this the same for the koni yellows? and if so, what has to be modified?
i would be buying the front two only - later the rears.
also does anyone think that buying two differnt brands one for the front and one for the rear is retarded? give reasons why!
Old Sep 18, 2006 | 09:36 AM
ALSOUSA99MAXIMA's Avatar
KYB AGX
They are eiasly adjusted
ebay like 350-400 for all 4
Old Sep 18, 2006 | 09:37 AM
MaximaSE96's Avatar
Maxima Owner
many people dont buy Koni rears cause they are not externally adjustable....and to install Koni's on the front u have to hack about the stock strut housing cause they are inserts that bolt into the stock housing...if i were to get too different brands i would get Koni fronts and Illumina rear...but like i said if u can get the Konis set perfect in the rear u dont have to adjust...i have mine set at about 3/4 stiff and havent touched them or want to
Old Sep 18, 2006 | 10:01 AM
RA030726's Avatar
I have koni fronts agx rear, but agx are junk IMO.
Installing koni inserts is nothing crazy. Google the directions for an idea of whats involved. I think its crazy that people dont buy the Konis just because of the front install and the rear adjustment. They are light years ahead of the others. If you dont want to do the work, I can mod the OE struts for you so all you have to do is bolt the Konis in.
Old Sep 18, 2006 | 10:36 AM
as much as i would love to have koni's i dont see any real advantage of spending money i dont have and then modifying the OE stuff just to get it to work. i do autoX but i dont do it everyday, and i dont do it for money
i guess im going to stick with one or the other.
Old Sep 18, 2006 | 10:42 AM
Cdg2125's Avatar
hey are gr2's really that crappy? I was thinking of getting some with h&r's? Any thoughts?
Old Sep 18, 2006 | 12:19 PM
RA030726's Avatar
capital J unk
Old Sep 18, 2006 | 12:26 PM
MaximaSE96's Avatar
Maxima Owner
if u shop around u can find Konis cheaper than Illuminas......I did
Old Sep 18, 2006 | 12:57 PM
Cdg2125's Avatar
Originally Posted by JSutter
capital J unk
Good Im staying away from those. AGX just as bad right?
Old Sep 18, 2006 | 01:12 PM
RKZ's Avatar
RKZ
What about HP blues?
Old Sep 18, 2006 | 01:14 PM
RA030726's Avatar
Pretty much but at least you can have the option of riding on bricks, rock, cement, or diamons. 1 feels just ok but is bouncy (ok compression but not enough rebound), 2 feels really over stiff for street already but is not bouncy( too much compression, ok rebound), 3 is just hard, 4 is just retarded.
GR-2 are 15% stiffer (which is BS) same as 2f/4r on AGX.
Old Sep 18, 2006 | 01:15 PM
RA030726's Avatar
Same as stock, but possibly slightly sportier . OEM struts are Tokicos anyhow.
Old Sep 18, 2006 | 04:24 PM
RKZ's Avatar
RKZ
What about Illuminas paired with eibach springs? what is everyone else riding on?
Old Sep 18, 2006 | 04:27 PM
Cdg2125's Avatar
I just wish I could find a good price on the illuminas and progress. I changed my mind on the springs because I dont want to spend over 800 for suspension. Unfortunately most setups that are good quality arnt cheaper.
Old Sep 18, 2006 | 05:24 PM
babymac's Avatar
BOOST 4 LIFE!
How about tein basic set-up??
Old Sep 19, 2006 | 02:19 PM
loverholic's Avatar
iAMIXAM!
there are KYBs on ebay for $195, are those any good?
Old Sep 19, 2006 | 04:38 PM
Prophecy1's Avatar
Any truth to the rumor that if you update your shocks/Struts that you need to update your springs because they will eat your oem springs up.
Old Sep 19, 2006 | 04:41 PM
Cdg2125's Avatar
No. New struts are fine with stock springs. Springs are what lowers the car so you cant have new springs on stock struts.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
