reset ecu after knock sensor replaced
Old Sep 19, 2006 | 07:56 PM
bogeyman007's Avatar
Well my cutting out at the upper rpms caued the code for the knock sensor so I replaced it with an autozone one today, it runs soo much better up to 3k but it still cuts out in the upper rpm, even after resetting the ecu, and the code is gone, no check engine lights. Does this just take time to go away or what else could it be?
Old Sep 19, 2006 | 08:01 PM
NmexMAX's Avatar
dot dot dot ...
Cutting out at high RPM is not KS related.
More likely MAF related or something else.
Old Sep 19, 2006 | 08:02 PM
I tested the maf today and it was fine
Old Sep 19, 2006 | 08:15 PM
NmexMAX's Avatar
dot dot dot ...
Seems as if the KS was not the problem...
Old Sep 19, 2006 | 09:14 PM
Godson's Avatar
When you say "cuts out",kinda vague,could be be a little more descriptive?
Old Sep 20, 2006 | 03:32 AM
it will be climbing smoothly and then cause you to jerk in your seat, it will not go past 5k rpms no matter what doesn't matter if I keep it floored.
Old Sep 20, 2006 | 03:33 AM
Well it runs much better after replacing it.......
Old Sep 20, 2006 | 04:38 AM
MaximaSE96's Avatar
Maxima Owner
sounds like it could also be a spark issues...
Old Sep 20, 2006 | 09:48 PM
MrDicks95SE's Avatar
Offset Is Everything.
its probably your MAF sensor. i had a similar problem. how do you mean you "tested" it? well even if you unplug it you still wont be able to tell unless you get out driving. its most likely an electrical short in the MAF sensor itself.
Old Sep 21, 2006 | 09:11 AM
Godson's Avatar
Yea thats sounds like some kinda MAF issue.
Old Sep 24, 2006 | 03:36 PM
ben805's Avatar
If I were you I would also pull out all the coilpacks and inspect them. make sure they are connected properly on the plugs as well.
Old Sep 24, 2006 | 04:01 PM
njmaxseltd's Avatar
Check the fuel filter and fuel pressure regulator.
The KS has nothing to do with your "cutting out" problem.
CorollaULEV
30
Aug 9, 2021 08:11 PM
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Oct 27, 2015 01:29 PM
maxinout93
Aug 20, 2015 02:17 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
