rear seats
Old Oct 4, 2006 | 03:12 PM
Valentine's Avatar
rear seats
hey i just got some black leather seats from a 99 max that was being parted out. the front 2 seats were easy to install. the back seat was giving me a problem. i removed the seat cushion and i can see the fuel pump and wires now but i cant get the back of the seats off. is there a writeup on this? any help on removing that seat is appreciated thanks.
Old Oct 4, 2006 | 03:29 PM
Fr33way™'s Avatar
Wild for Width
Fold the armrest down, behind a piece of material there are two 10mm.
There are two 10mm on the lower outside area. From there the seat hangs on three "hooks" that come out of the rear deck. pulling the bottom toward you, lift the rear up after all four (4) 10mm have been removed.
Old Oct 4, 2006 | 06:13 PM
Valentine's Avatar
plz forgive my stupidity i dont see no bolts? u got any pictures or writeups?
Old Oct 4, 2006 | 06:42 PM
Fr33way™'s Avatar
Wild for Width
In the area where there is a hole, just below the opening there are two 10mm. They are BEHIND the gray piece attatched to the armrest.
The others should be easy to see with the bottom of the seat out, run your hand along the bottom, they are on the lower outsides (one each).
Old Oct 4, 2006 | 06:54 PM
nitromax's Avatar
look at the seatback that is out, the one you're gonna put in, in the area of the armrest, there is a bar going across the bottom of the opening. the two holes you see in that bar are where the bolts are on your car. now look at the outside bottom corner of the seatback, there are wire loops,that's where the other bolts are on the car. to get to the bolts in the bar, lift the plastic piece on the end of the material off of the bar.
Old Oct 4, 2006 | 06:56 PM
nitromax's Avatar
damn i type slow, answer already in b4 me
Old Oct 4, 2006 | 07:12 PM
Fr33way™'s Avatar
Wild for Width
As long as it helps....
matts95max
Apr 23, 2025 10:44 AM
AcuraLegend
Oct 17, 2016 08:47 PM
doctorpullit
Sep 10, 2015 06:33 PM
ef9
Sep 5, 2015 11:18 PM
