Iacv question for the dek swap I got a idea?
Old Oct 9, 2006 | 06:50 PM
95turbo gxe's Avatar
ok im looking at the 5th gen iacv housing. it just has and air passenge before the throttle body and one right afterthe throttle body into the manifold.The 5th gen pulled air to the iacv from both into the same to the iacv. On the 4th gen it pulls from the mid pipe and the manifold. But what I was wonder if i could just take the off the 5th gen iacv and weld a nippel on to it to send my hose to the 4th gn iacv.and run a hose to the other connection on the 4th gen iacv to the mid pipe. As you can see in this pic with it removed!
I would jsut mak a plate to go on the 4th gen iacv. and make a nipple and send it to the whole in the pic where the 5ht gen iacv was.
AS you can see in this pic the two air passenge. the middle is a water jacket so I can keep the water to the throttle body.
So what do you think would it work right.
Old Oct 9, 2006 | 07:16 PM
Tatanko's Avatar
Bacon Lover
I'd try and give a response but I'm not sure I fully understand what you're doing. Why do you want to use both? Why not just one or the other?
Old Oct 9, 2006 | 07:29 PM
sergofast's Avatar
I think what he is saying is that "if" it would work on an 00vi install where you want to use the 4th gen IACV and a DEK TB with a block off plate for the DEK IACV, that because it was the location for the stock DEK IACV, why would it not be a good location for the vacume line for the 4th gen IACV?
Makes since, and could prove to be a very clean install....and easy to fab up a block off plate and just install a 3/8" nipple for the line.
Plus you wouldnt have to worry about the lack of the correct size nipples on the 00vi upper.
Im I on track here?
One problem if you plan to keep the DEK IACV and gut it of its componets to just use for a vacume location would be the size.....you would have to re route lines under the TB because there isnt enough room.....but if its possiable it would make more since to fab a block off plate like the one pictured on Tantanos website and install a nipple.
Old Oct 9, 2006 | 08:03 PM
Im I on track here?
yes that kinda what im saying. i would make the two 1/4 plates to go onto the 4thgen iacv and run a hose from the back plate to the 5thgen block that goes onto the throttle body. (right on the front where the old sensor was for the 5th gen. ) Ill put a 1/2 nippel on it and run the hose back to the 4th gen iacv plate. That way I dont have to tap the plastic manifold and keep the water line to the throttle body. tell me what you think?
Old Oct 9, 2006 | 09:32 PM
sergofast's Avatar
I might be jacking this alittle, but its related...
If you are using the DEK TB and want to still have the water line, but are using a block off plate instead of the factory DEK IACV, could you just install two nipples on the block off plate and run the water through that? Wouldnt thes help with cold starts.... Im not going to use the DEK IACV because i dont want to re-route all the lines under where it would go.
Old Oct 9, 2006 | 09:38 PM
sergofast's Avatar
I think you have them mixed up....the "dirty" ones are the water passages. the "clean" one that the factory DEK IACV goes into is the air. so if you were to make a block off plate and install the in and out nipples for the water, they would have to be lined up with these two "dirty" passage. if you wanted vacume it would have to be with the larger "clean" passage
Old Oct 10, 2006 | 02:48 AM
no im sure the dirty ones are air if not the throttle would be flooded with water.
Old Oct 10, 2006 | 02:55 AM
matty's Avatar
Dirty ones are water. Clean are vaccum. It seals off when you connect it to the TB.
Please explain what you are trying to do. I dont understand fully.
I just blocked off the TB where the 5th gen IACV goes to, and just used my 4th gen IACV. Using both is kinda pointless and there really isnt alot of room in there.
-matt
Old Oct 10, 2006 | 01:07 PM
sergofast's Avatar
is it even needed to have the coolant going through the TB? I know that this is what most people have made
would it seal up correctly to install three nipples on this: two for coolant in and out, and one for vacume to be run to the 4th gen IACV?
Old Oct 10, 2006 | 01:12 PM
-matt
The dirty one are air! look at it close. Ok im not going to have the 5th gen iacv sensor in im just using the hosuing to put a nippel on it to hook to my 4th gen iacv! and ill still have the water lines for the throttle body.
Old Oct 10, 2006 | 01:25 PM
sergofast's Avatar
perhaps you should ask in the all motor forum....thats where most of the 00vi swaps have been done.
Even if your not going to have the 5th gen IACV sensor in and fab up a piece to cover where it is, and install nipple for the 4th gen IACV that you will be using, there is not enough room for the assembly to fit. thats one of the reasons why the block off plate has to be fabed up. Unless you could install the three nipples like i described above, it would probably be more work than its worth because you would have to re-route everything below where it would be located.
Old Oct 10, 2006 | 01:47 PM
toddemullins's Avatar
Got your PM sergofast. I think what you are proposing is feasible, as long as you rerun all the vacuum spiders under the TB. As matty said, there is virtually no room under the TB unless you rerun all the spiders. I have a spare 5th gen IACV plate and had thought of doing exactly what you guys are talking about until I saw the clearance issues. It would make for a clean install, but more work rerunning the vacuum. Just my .02.
Finkle
Sep 27, 2015 09:53 PM
schmellyfart
Sep 25, 2015 04:47 PM
Johnny9595
Sep 3, 2015 05:18 AM
Maximeltman
Aug 31, 2015 01:01 PM
Blackwind
Aug 5, 2015 06:35 PM
