Bought A 99 SE
Old Oct 12, 2006 | 08:09 PM
Spartuss's Avatar
Bought A 99 SE
Hey All-
Yesterday I bought a 99 SE Automatic. One question though.
The preveious owner used 87 octane gasoline. I know our cars' take advatage of 93 octane due to the compression. Will I have to disconnect the battery after putting in 93 octane for the ecu to reset. Or will the car advance the timing accrdingly itself?
Old Oct 12, 2006 | 08:22 PM
kil2board's Avatar
car should advance the timing itself. Nissan blessed us with the wonderful invention of the knock sensor for our cars. it automatically advances or retards the timing upon initial spark to reduce the chance of detonation. Long story short, GAS N GO.
Old Oct 12, 2006 | 11:56 PM
nguyen925's Avatar
what i'm planning to do with the next fill up is go 93 as well, do i need to allow my gas tank (with is filled with 87) to drain till the lights on? i know its not recommended that you let the car run on nearly empty but i'm having a serious issue with mixing old 87 + 93. any suggestions?
edit, im also planning on running some fuel injector cleaner in there as well.
Old Oct 13, 2006 | 03:53 AM
BlackMaxdout's Avatar
mixing 87 and 93 isn't going to hurt anything. You're just going to have mixed octanes for a while.
Old Oct 13, 2006 | 04:13 AM
natty99's Avatar
yeah, actually mid-grade gas is a mixture of regular and premium gas, just in different ratios. So in effect, you'll be running mid-grade for a while, unless you just happen to dilute the **** out of it by running the tank low on 87 and then filling it up with 92 or 93. No matter what though, the maxima is a smarty: it can figure out what it needs to do operations-wise given a certain grade of gas. Go forth without paranoia, you and your car will be ok
Old Oct 13, 2006 | 05:20 AM
95GLEMAXX's Avatar
check your codes and make sure your knock sensor works too
Old Oct 16, 2006 | 03:47 PM
adriena's Avatar
does knock sensor mess with your gas mileage?
Old Oct 16, 2006 | 08:49 PM
FX45's Avatar
I've been filling up with 93 since i bought the car and the previous owner used 87, and now after the 3rd fill I can feel a bit of a difference already
Old Oct 16, 2006 | 08:53 PM
ethnic6's Avatar
good job on the guy, no the gas difference shouldn't do anything to ur car, now go take some pictures and post them on the member's ride section
Old Oct 17, 2006 | 06:56 AM
Ward's Avatar
what's the difference you fell??
Old Oct 17, 2006 | 01:49 PM
nguyen925's Avatar
yes i would like to know the difference. i just filled mine up with 93 for the first time. 31$ for 14 gallons..
Old Oct 19, 2006 | 08:06 PM
Game_Time's Avatar
Congrats on the car
Old Oct 19, 2006 | 10:32 PM
oldskooljdm's Avatar
fill up with 93' and go as previously stated and check for knock sensor failure. knock sensor failure will retard the timing and would have affect on mpg and hp loss. ive ran a full tank of 89 through mine one time and noticed that i didnt go quite as long before next fill up. or maybe i drove harder?
Old Oct 19, 2006 | 11:14 PM
MainSource's Avatar
Hit 'em with the stun gun
Congrats on the purchase.
Stay on top of the knock sensors like most already stated and fill 'er up with 93!
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
REDinLV
Sep 28, 2015 12:31 AM
Sep 27, 2015 08:37 AM
