Help: Anyone with a Haynes Manual
Old Jun 28, 2001 | 05:58 PM
Maxima48177's Avatar
Can anyone with a Haynes Manual for a 4th gen Maxima let me know what the torque specs are for a 95-96 Maxima 5speed for all the bolts relating to the tranny and clutch. Please help! Thanks Alot.
Old Jun 28, 2001 | 06:17 PM
Sprint's Avatar
Manual Transaxle
Bolt A (52mm) 51 to 59 ft-lbs
Bolt B (65mm) 51 to 59 ft-lbs
Bolt C (124mm) 51 to 59 ft-lbs
Bolt D (40mm) 26 to 35 ft-lbs
Bolt E (40mm) 26 to 35 ft-lbs
Old Jun 28, 2001 | 06:19 PM
Sprint's Avatar
Clutch and Driveaxles
Clutch master cylinder retaining nuts 69 to 96 in-lbs
Clutch release cylinder retaining bolts 22 to 30
Clutch hose to release cylinder banjo bolt 144-168 in-lbs
Clutch pressure plate bolts 25 to 33
Support bearing to bracket bolts 108 to 168 in-lbs
Driveaxle/hub nut 174 to 231
Old Jun 28, 2001 | 06:32 PM
Thanks alot Sprintmax for all your help! I need one more spec though, can you help me find the torque spec for the one to attach the flywheel to the crankshaft? Thank You.
Old Jun 28, 2001 | 06:39 PM
Sprint's Avatar
Camshaft sprocket bolts 88 to 95
Camshaft bearing cap bolts
Setp one (tighten the No.1 bearin cap bolts, first
[bolts 13 through 16] then follow the tightening sequesnce 17 in-lbs
Setp two 52 in-lbs
Setp three 80 to 104 in-lbs
Crankshaft pulley bolt
Step 1 29 to 36
Step 2 tighten an additinal 60 degrees
Old Jun 28, 2001 | 06:40 PM
Sprint's Avatar
Driveplate bolts 1 to 69
Old Jun 28, 2001 | 06:48 PM
What do you mean? Do you mean 1-69 ft-lbs? or in-lbs? I think the number I'm looking for is under engine mechanical near the front. It suppose to have 9 bolts. They're either called driveplate bolts or flywheel bolts. Thanks for all your help. I really appreciate it.
Old Jun 28, 2001 | 07:04 PM
Sprint's Avatar
1-69 ft lbs
Old Jun 28, 2001 | 07:12 PM
1-69 ft lbs
Old Jun 28, 2001 | 07:17 PM
Sprint's Avatar
no problem
my03maxima
Jul 28, 2024 07:40 AM
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
doctorpullit
Oct 28, 2019 10:58 PM
