Fuel Injector Removal
Old Oct 19, 2006 | 03:50 PM
Curt's Avatar
Is there a secret, simple, easy way to remove the injectors if you're not also removing the fuel rail (i.e, popping them up and out) without damaging them?
Old Oct 19, 2006 | 04:05 PM
Jatan's Avatar
Loosen both screws with a vise grip when your car is cold (screws might be too soft for just a screwdriver):
Remove both screws and the metal cap. Then put the 2 screws back in (not all the way):
Use L keys or small screwdriver as leverage to "pop" it out:
You can see the damage to my injector from just using a vise grip on top (tried to pull it out that way but that didnt work)
Old Oct 19, 2006 | 05:42 PM
RA030726's Avatar
I'm nutty for Nissans
Bingo! thats the way to do it.
Old Oct 20, 2006 | 03:38 AM
Curt's Avatar
Thanx, guys. I got the Phillips head machine screws out OK, and replaced them with Hex-head bolts (M5 x 16 mm - 0.80 pitch (metric)). Good idea about using the loosened bolts as lever-posts.
Oh, and BTW, for loosening those as well as other such soft, Phillips-head machine screws on the MAX (e.g., the ones holding the VIAS to the 00VI), I find very effective the hand-held impact driver I got years ago at Sears.
Old Oct 20, 2006 | 04:32 AM
crazy97's Avatar
An impact driver is awesome on screws like that.
Old May 17, 2012 | 05:00 PM
nab911's Avatar
I just want to bump this and say thank you soooo much for this. I destroyed my old injecor and could not get it out. Put the screws back in and used to allen wrenches, popped right out. THIS SHOULD BE STICKIED!!!
Old May 17, 2012 | 06:33 PM
atriuum's Avatar
Werd.
I have a whole set of injectors I've been putting off replacing because I hadn't quite figured out how to get the ****** out. So they're getting done now.
Old May 17, 2012 | 07:07 PM
nab911's Avatar
It's stupid how easy it is after finding this thread. I literally DESTROYED mine and then they popped right out doing this.
And if you strip those screws, instead of drilling them out, just take a dremmel with a cutoff wheel and cut down into the head to make it a big flathead. Had to do that with one of mine and it was soo much better.
Old May 17, 2012 | 08:09 PM
Trini Boom's Avatar
Ain't this some crap. Never saw this thread either. I was doing it partially right though by breaking screws with vise grip first. Getting the injector out, I used the same vise grip to hold top part and twist and pull at same time. Good thing those injectors were not getting reused. Is there a special tool for this?
Old Aug 29, 2012 | 06:53 PM
bksmax11203's Avatar
Def neesa to be stickied. I went to the junk yard today to get some and couldnt get them out so said F it and went for the fuel rail. Damn idiots tried to charge me $35 for it and told me they cant and i cant take out an injector. Have to purchase the whole damn rail
Old Sep 4, 2012 | 09:27 AM
niko_jdm's Avatar
oh yea this really gud i have a bad injector, tried to mess with this morning and it woundnt come out. i think im am going to go bck and try it again using this.
Old Sep 4, 2012 | 04:22 PM
Rob_0126's Avatar
You are using bolts to replace the stock injector body screws?
Id like to upgrade those soft heads myself. I had to get some extras at the junk yard when I was doing some work(those bolts are used all over the engine).
Old Sep 4, 2012 | 05:09 PM
ShocknAwe's Avatar
These will fit, much better:
http://www.z1motorsports.com/product...oducts_id=4454
Old Sep 4, 2012 | 08:06 PM
styliztik's Avatar
Off topic; those fuel rails in the pics are pretty nasty looking. Lol
Old May 22, 2013 | 10:29 AM
alongshot's Avatar
Thanks for the great tip! The L-shaped hex wrench along with putting back the screws helped me pull out the fuel injector very easily.
I had code P0302 (Cylinder 2 misfire) and white smoke was coming out of the exhaust that smelled like gasoline. My 99 Maxima (239,xxxx) had a rough idle too. I noticed this problem recently and the CEL came on really quick. After reading some threads on this forum, I knew it had to be the fuel injector since I replaced all ignition coils (OEM) and spark plugs (NGK Platinum) 3 years ago.
After replacing fuel injector #2 and resetting the CEL, the problem is now gone. This forum is great! Thanks everyone...
Old Sep 18, 2013 | 02:32 PM
cashoit's Avatar
BUMP!!!
So i narrowed my misfire down to cylinder 6. Came across this thread and YAY!!!
My question is how can i test the injector? Put a screwdriver up to it and listen for the click? I know i can do a ohm test per FSM as well.
Old Jul 1, 2015 | 03:55 PM
gp540's Avatar
Food for thought I pulled 12 injectors for my 3rd gen today at the yard.
Remove screws (carefully they are soft metal)
Remove plate. ( throw across yard if applicable)
Then I twisted the injector
1/4 in extension with 1/4 socket and closest Allen head that fits into injector hole
Pry off another screw drivers handle while pulling up with your hand ( prevents injector and your tools going flying when it pops)
See photo (minus my hand holding injector as its holding a camera.)
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
