replaced knock sensor and harness, 0304 still there, help!
last night i was successfully able to remove the knock sensor only to find that the two prongs in the sensor measured 550 ohm(or kilo ohm or whatever the unit is), exactly the same as the replacement i bought! i figured what the hell since i already bought the new one and replaced it. reset CEL, then tested for codes again and 0304 popped up immediately. i thought it might be the harness and went to buy a new harness this morning. reset and retested CEL and same thing there still. what else can i do? i read that to test the sensor by probing one of the pin and engine ground with a ohm meter, i tried and always get 1. please help.
Originally Posted by nitink
I think you have to clear the code, it won't go by itself
also, what i don't understand is how you can get a reading at the pins in the socket. the sockets has two pins but on the sensor side there is only one wire. i cut up the old harness to see that the black or ground wires just ends there and not connected to anything. so with the sensor plugged in, the two pins in the socket on the other end is not closed and should be infinite resistance. the haynes manual said that if the reading is infinite, then the sensor is bad. thats why i thought mine was bad and bought a replacement. but testing the new sensor in the new harness also still shows 1...
From FSM
Knock Sensor Diagnostic Procedure
1. Loosen and retighten engine ground screws (front of intake manifold)
2. Check input signal circuit - 1
Ignition OFF
Disconnect ECM harness and knock sensor sub-harness
Check continunity between terminal 1 of sub harness (connector on top, left pin) and ECM terminal 64
Continunity should exist
If OK check harness for short
3. Check input signal circuit - 2
Check resistance between terminal 1 and engine ground
Resistance appx. 500 - 620 K omh
Inspect knock sensor
Check resistance between terminal 2 (left pin) and ground
Appx 500 - 620 K omh @ 77 degrees
Ignition OFF
ECM is the big wiring harness on the ECU right? or am i mistaken? how can you physically test for continunity between the knock sensor harness in the engine bay and the ECM in the cabin? please correct me if i'm wrong.
Drive the car for a week and check for any stored codes once again.
My body harness is open or shorted between the ks subharness and the ECM, and after clearing the code with the screw or an OBD-II scanner, it'd pop back up instantly. It stopped doing this when I ran a straight wire from the body side connector to the ECM connector.
Tighten the bolt on the KS.
When I replaced my KS and reset the ecu the code returned as a ghost code (no cel). So I inserted a wrench there , tightened it and no code since then. I seen some threads here about KS problems and they said if the bolt is overtightened or undertightened the KS will partially work.
You'd need to torque that knock sensor down to the recommended specs. Our knock sensors are sensitive piezoelectric transducers. They will need to be compressed correctly to get the "engine noise". If torqued down too light, they will not hear much, or they'll even vibrate, creating additional frequencies of engine noise, and possibly crack the sensor again. If it's torqued down too tight, it will be too sensitive and also pick up additional noises, this will make things harder for the ECU to interpret what's really going on. You'd have to search the torque specs about it, I already forgotten all the numbers.
You'll also have to check your O2 sensors. These O2 sensors, when partially faulty, will not trigger CEL's unless driven a couple hundred miles, upon and after reset. If O2 is bad, 0304 code may or may not appear recursively.
-Peter-
-Peter-
Don't mean to hijack but I can't post yet, that damn limiter is getting old.
At any rate I just replaced the knock sensor in my 95 max, code is still there as well. I reset the ecu, I believe anyway its the same process as pulling the codes right? turn the screw, turn it back turn the key off good to go right?
Anyway yea 0304 is still there, maybe its in the wiring harness?? anyone encounter this? thanks
Man, I'm and idiot I swear, i just got done typing this, went to go sit on the couch and I got to thinking, wait an minute you gotta do that whole turn the screw thing twice I think....came on here checked to make sure my thinking was right and it was
Sorry to have wasted your time by reading 2 of my posts, I think it was just a minor brain malfunction thinking I only had to do it once
Long story short the code is gone
mrc00l88
Jan 25, 2024 01:14 PM
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Aug 20, 2015 02:17 AM
doobadoo
Aug 15, 2015 06:43 PM
