EGR issues
Old Oct 30, 2006 | 08:38 AM
Me[kk]A's Avatar
EGR issues
hey all, well i recently replaced a clogged cat and turns out it screwed my entire EGR system. This includes the BPT valve and the solenoid as well as the valve.
What i need a hand with is to find a photo or engine diagram showing how the egr solenoid and bpt valve look to show my parts guys. Ive tried google, and my nissan dealers but to no avail. Would anyone happen to have a link for these? much thanks.
Old Oct 30, 2006 | 11:19 AM
CRiME's Avatar
oem ftw!
Actual picture of the EGRC solenoid valve (Nissan part # 14956-31U10)is in this thread:
http://forums.maxima.org/showthread.php?t=494199
diagram of all EGR related parts:
http://smg.photobucket.com/albums/v1...tart=#imgAnch5
Sounbwoy has probably the most informative EGR related thread with very good pictures. I actually think it should be added to the stickies:
http://forums.maxima.org/showthread....t=egr+sounbwoy
The solenoid is a pretty easy job to do yourself. just make sure the engine is cool and use an open end wrench. I did mine over the weekend, and my 10-05 code went away. I'm not sure about the other stuff though. Maybe you can try replacing the solenoid valve first and then resetting the ECU to see if your codes return.
Old Oct 30, 2006 | 01:02 PM
Jokester66's Avatar
Ive been battling my EGR code 03 02 for a year.... i took it to nissan to see what they said, and they said EGR is clogged, i need a new water pump, and fuel system cleaned for 1400$ and he took off 250 to help me out (what a guy) so i told my friend who is a mechinic at Ford and he took it in and found 1 bad clogg and installed a new water pump and cleaned my fuel system for 550$
Now 2 days later the codes are back and i dont know what else to do?
Old Oct 30, 2006 | 01:44 PM
CRiME's Avatar
oem ftw!
Look at the link I posted to Sounbwoy's thread. More than likely if you do everything that he did in that post, your problem will be solved
Old Oct 30, 2006 | 01:55 PM
Kelleybean's Avatar
My maxima just popped up with this code after fixing the knock sensor... I didnt buy another Jeep cause they are money pits... I hope my new maxima doesnt turn into one...
Old Oct 30, 2006 | 03:13 PM
CRiME's Avatar
oem ftw!
Which code did you get? 10-05? It's funny that you say that, I think I actually broke my solenoid valve while forcing my hand in there to retorque my knock sensor . After I was done with the KS, the 10-05 EGRC code came up within 5 miles. The location of the solenoid valve makes it even more of a pain to get at the KS!! If you have the 10-05 code, do the simple things first; check to make sure that you reconnected the wiring harness to the egrc solenoid valve. If you still have the light then you may have accidentally broken the valve as I did
Old Oct 30, 2006 | 03:55 PM
Kelleybean's Avatar
No, I'm getting a 03 02 code.
Old Oct 30, 2006 | 04:12 PM
Kelleybean's Avatar
Sounds like it's time to do some "crud" cleaning.
Old Oct 31, 2006 | 08:47 AM
nhaven's Avatar
Here's how I solved mine
http://forums.maxima.org/showthread.php?t=496494
Old Oct 31, 2006 | 08:51 AM
Kelleybean's Avatar
Originally Posted by nhaven
Thanks I will check it out!!!
Old Nov 1, 2006 | 07:52 AM
Me[kk]A's Avatar
So what symptoms car wise did you guys have when your cars were pulling the EGR and IACV codes? mine has both and it runs hard, slow to accelerate, the motor revvs high on the highway (as if its strained) and i have a nasty flutter in my motor by the throttlebody and intake manifold that is now the lowest tone of noise when the engine is running
shilov
Feb 19, 2024 09:40 PM
KabirUTA13
19
Oct 17, 2015 02:15 AM
JoshG
51
Sep 21, 2015 10:41 PM
bumpypickle
Sep 20, 2015 08:22 AM
bumpypickle
Sep 19, 2015 01:07 AM
