BBK Part Sourcing
Old Nov 2, 2006 | 08:31 PM
86maxima96's Avatar
I Broke OT
BBK Part Sourcing
I'm putting a BBK together. I'm trying to decide if I should go with the 12.6" rotors (from 04+ Maximas, right?) or the 13" Cobra rotors (which years are used for these?). I'm not sure where most people tend to get their rotors from or how much each one is.
So those who have a BBK using the Z32 caliper, which rotor did you go with and why?
Old Nov 2, 2006 | 09:52 PM
Cdg2125's Avatar
I think the 5th gen rotors are a good call since they are only .4" difference. The 5th gen rotors can be found for cheaper and will work just as good with some double piston calipers or even the 5th gen calipers. Thats what I've read up on at least and I will be doing in the future.
Old Nov 2, 2006 | 09:53 PM
happy4444's Avatar
im thinkin if your autoXing.. or have the money to blow then go with the 13in cobra and 300z calipers.. i mean no matter how u look at it ur gonna need bigger wheels... brake bias is gonan be an issue most likely..
personally id go with and i am goin with 13in cobra rotor and q45 calipers...
i found rotors cheaper all over but automax seems to be the only one who can redrill them to maxima spec or w/e that is.. cobra rotor years are like late 90's im pretty sure..good luck and let us know how u make out w everything
Old Nov 2, 2006 | 10:08 PM
86maxima96's Avatar
I Broke OT
I think you mean 6th gen, right? I think rotors from 89 all the way to 03 are the same. Not until 04 do they get any larger, specifically 12.6".
Old Nov 2, 2006 | 10:30 PM
Cdg2125's Avatar
Yeah 6th gen. I apologize. It's been a long day haha
Old Nov 3, 2006 | 04:47 AM
MaximaSE96's Avatar
Maxima Owner
i chose the 6th gen rotors mainly because u dont need the hubcentric rings....and fit perfectly.....the .4 of an inch difference hasnt shown to hurt me on roadcourses or auto-x......plus i got matts brackets on sale and they came with covnersion lines...less part sourcing...i got my rotors from rockauto.com they are Raybestos rotors and i havent had any issues with them.....04/05
Old Nov 3, 2006 | 10:09 AM
86maxima96's Avatar
I Broke OT
yea, i would think that once you upgrade to the 4 piston calipers and the significantly larger rotor, either setup shows huge improvements over stock. and yea, the cobras require redrilling for the studs and the hubcentric ring.
so matt makes the brackets for the 6th gen rotors and jeff for the cobras?
Old Nov 3, 2006 | 10:15 AM
Jeff92se's Avatar
I'm needing a caw
IMHO from what I've read. 4 piston calipers if the total piston area is larger than OEM than yes, it will increase breaking force. But it's mainly for braking feel and fade resistance.
Most of the increased braking force is from moving the caliper out and thus increasing the torque arm force. So in theory a caliper moved out to accomodate a 13" rotor should be able to have more torque arm force than a caliper accomodated for a 12.6". But both are much better than stock and the diff inbetween a 13" and 12.6" is not nearly as large as the move up from the stockish 11.x" stocker.
Old Nov 3, 2006 | 01:01 PM
Cdg2125's Avatar
I was under the impression that there were no custom brackets needed for using the 6th gen brakes...?
Old Nov 3, 2006 | 01:39 PM
86maxima96's Avatar
I Broke OT
like Jeff said, stock 4th gen rotors are ~11" while the 6th gens are 12.6" i don't see how you can get around that without a bracket to move the caliper out.
Old Nov 3, 2006 | 01:42 PM
Cdg2125's Avatar
Because I though you only had to redrill the bolt holes....apparently I'm wrong. Jeff how much do you charge for those brackets?
Old Nov 3, 2006 | 01:43 PM
Jeff92se's Avatar
I'm needing a caw
There are alot of brake kits out for the maxima. You guys need to really read closer.
If you use the 6th gen rotors AND CALIPERS, it's bolt up(aside from the drilling of the bolt holes). 6-gen calipers are huge one piston jobs though. Using the Q/J or 300z calipers, the a bracket is necessary
Old Nov 3, 2006 | 01:44 PM
Jeff92se's Avatar
I'm needing a caw
brackets/rings are $90 shipped for the set
Old Nov 3, 2006 | 01:45 PM
MaximaSE96's Avatar
Maxima Owner
what jeff said...it all depends on what caliper setup u use
Old Nov 3, 2006 | 01:49 PM
Cdg2125's Avatar
So I was right. I plan on using all striaght 6th gen parts. You think it's more worth it to upgrade to bigger calipers? I dont autox or anything. Just want a little better stopping power for a fairly cheap price...Jeff you know all about this stuff. Help me out.
Old Nov 8, 2006 | 10:49 AM
Jeff92se's Avatar
I'm needing a caw
I think it's great cost effective upgrade. You should be happy with it. If not, you can always sell and upgrade again.
Old Nov 8, 2006 | 12:10 PM
Cdg2125's Avatar
Ok thanks Jeff. I like the idea that I dont really have to mod too much stuff and get better performance. It'll be a while since I'll need bigger rims for the setup. Rims come much later so...
derekinthez
Nov 13, 2022 04:00 PM
BkGreen97
Apr 2, 2016 05:47 AM
Hdnseek
Sep 9, 2015 05:55 AM
TheMafia
Sep 4, 2015 08:26 AM
