OMG help please i am actually desperate PLEASE!
Old Nov 5, 2006 | 07:28 PM
Luisjo's Avatar
Ok. so i know there is alot of "bad gas milage threads" bu mine is a little EXTREME in the way that my car consumes 50 litters in about 115 miles!!!!!!! thats like 5 miles the galon the only thing i have done is an air fileter (K&N) but had to disconect the intake sensor. i really need help im literaly filling the car every 2 days and thats like 27$ every 2 days and thats a lot. oh and i have a 1995 maxima SE
Old Nov 5, 2006 | 07:36 PM
99se5speed's Avatar
SHIFT_up
Did you try doing a tune up? That might help. Check for any codes even if the CEL isn't on. You might have ghost codes that don't trigger the CEL. I just don't understand how you fill up for 27 bucks? You use regular? even then it shouldn't come out to 27 for a full tank.
Mxrider52's Avatar
I support for what?
CEL? KS code? When last times plugs been replaced? Fuel filter? Brake calipers seized up causing drag?
Old Nov 5, 2006 | 07:38 PM
Max_Out's Avatar
Under the radar
Change Knock Sensor, being a 95 it might be due for one. also take your car to a garage and have them do an engine flush, clean the throttle body, and do a fuel system cleaning. make sure your air filter is clean... thats just the things that come off the top of my head. do all of that and if it doesnt help then you have a serious problem and need to take it to a reputable mechanic.
Hope this helps
-Colin
Old Nov 5, 2006 | 09:31 PM
Luisjo's Avatar
Thanks. by the way the CEL is on i just didnt check it because did it 3 times and got de same codes (coolant temperature sensor, and the other one dont remember) but i will try that now (even though its 1:32 in the morning). And i fil the tank up with 27$ yes i use regular and here in puerto rico is at 49.7 per gallon (in some places). so thanks and i will let you know what codes i got.
Old Nov 5, 2006 | 09:49 PM
Luisjo's Avatar
So... i cheked the ECU for the CEL and found out i only have the code 04 01 (Intake Air Temp Sensor) because i took out that sensor to put my new intake.. is this causing the milage to be so bad (BTW i am at 1/4 of the tank and only drove for 108 miles and thats awfully bad). i will go ahead and try to do what you guys told me and see if it solves anything.
Old Nov 5, 2006 | 10:00 PM
ethnic6's Avatar
did u check to see if ur Knock Sensor is bad? replace it and see if there is any difference
Old Nov 5, 2006 | 10:20 PM
Luisjo's Avatar
i dont wanna sound like a poor fellow or something. The thing is that i didnt got it on the CEL diagnostic. and since i read that the knock sensor cost a lot (or something that people always talk about) i dont wanna go and replace it and then find out that i didnt needed it.
Old Nov 5, 2006 | 10:51 PM
loverholic's Avatar
iAMIXAM!
DAAAAMMMMNNNNN.......... when i fill up my tank, i get 108 and my needle is still on the 3/4 mark..... and i thought i had bad gas milage.... did you do a V10 conversion?... j/k ok sorry this is too bad to be making jokes..... this is beyond bad... go to a shop and have your entire fuel system checked, you might have a leak in your fuel system.... with 140 miles per gallon, you better off investing your money in an entire gas station.....
Old Nov 5, 2006 | 11:23 PM
nitink's Avatar
On that kind of MPG, I think you are loosing gas, there may be some pinhole leak some where (check Gas Tank and line to fuel filter for leaks).
Old Nov 6, 2006 | 02:35 AM
ewuzh's Avatar
A leaking fuel injector would cause this too. Change your oil and if it comes out smelling like gas, STOP driving and fix the leaking injector ASAP. Gas + oil = no lubrication = spin a bearing.
Old Nov 6, 2006 | 02:38 AM
SEmy2K2go's Avatar
Go BUCKS!!!
Hook your MAF sensor back up
Seems like a pretty easy fix to me.
Old Nov 6, 2006 | 04:03 AM
Luisjo's Avatar
i know mi milage is bad. But something that i noticed (dont know if its important) is that when i drive to any place the cars fine and as soon as i stop and park i notice a white smoke coming out of where the gasoline is supposed to be burning y dont know if its leaking and then evaporating... just to let you know and by pure coincidence when my milage became that bad thats when it started hapening
Old Nov 6, 2006 | 07:01 AM
DJ420's Avatar
Bad Mother Fornicator
ok. coolant temp sensor will definately cause bad gas mileage. disconnected IAT will cause bad gas mileage. if your new intake has no place for a IAT, just plug it in and let it hang there in the compartment, OR drill a hole in the pipe and mount it. but dont REMOVE it. if white smoke is coming from the tail pipe, sell it or park it and fix it.
DJ
Old Nov 6, 2006 | 07:38 AM
ewuzh's Avatar
If it's small amount of white smoke then it's probably coolant. I had MASSIVE amounts of white smoke coming out of the tail pipe when my injectors were leaking fuel. I was also getting 2mpg, but I didn't drive the car more than a few miles. If your problem is a leaking injector (o-ring seal or physical injector leak), DO NOT DRIVE ANYMORE. You need to fix that **** ASAP or you'll be in the shop swapping in a new engine real soon.
Old Nov 6, 2006 | 03:25 PM
Luisjo's Avatar
OMG i will send it to a mechanic right away to get it fix (maybe this weekend, because i cant be without the car) i dont want to damage the engine and the smoke is NOT alot firs i opened the trunk and since it was little i tought maybe is because is hot. so im going to get it inspected. also i am getting like 5 MPG
Old Nov 6, 2006 | 05:40 PM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by SEmy2K2go
A leaking fuel injector would cause this too. Change your oil and if it comes out smelling like gas, STOP driving and fix the leaking injector ASAP. Hook your MAF sensor back up
... ... ... Check and fix all codes while you're at it.
Do this also. Once all these items are taken care of, you should be fine.
Old Nov 6, 2006 | 06:10 PM
MaximaSE96's Avatar
Maxima Owner
if his MAF sensor was unhooked it wouldnt go past 2k....plug ur intake temp sensor back in and just zip tie it somewhere for now....check for leaks...are u having starting issues
Old Nov 7, 2006 | 04:46 AM
Luisjo's Avatar
The intake sensor i cant plug it anywhere i have "hangin" there... Unless i put the other filter back. Im not having starting issues though
Old Nov 7, 2006 | 05:48 AM
MaximaSE96's Avatar
Maxima Owner
is the harness plugged in to the sensor itself..and the sensor is just hanging...or is the actual plug that goes into the sensor unplugged too
Old Nov 7, 2006 | 06:08 AM
Luisjo's Avatar
The sensor that went in the filter tube is unpluged but the other one next to it (that goes in the little box next to the filter) is pluged in.
Old Nov 7, 2006 | 06:10 AM
scubasteve's Avatar
OHHH YEA SCISSOR!!!!
Plug everything back in, sounds pretty simple to me.
Old Nov 7, 2006 | 06:21 AM
mbrock15's Avatar
were you getting that bad of mileage before in installed the new intake?
Old Nov 7, 2006 | 06:37 AM
MaximaSE96's Avatar
Maxima Owner
plug everything in...even of the temp sensor isnt in the intake tube.....are u having any starting issues
Old Nov 7, 2006 | 06:38 AM
Mximus's Avatar
Check your plugs, my brother had the same problem on a VR4 and it was the plugs. They had never been replaced and were firing terrible.
Old Nov 7, 2006 | 06:41 AM
scubasteve's Avatar
If he wasnt having the issues before, than its pretty simple to say it is something he changed, ie the intake. Plugs, wires, etc arent very likely.
Old Nov 7, 2006 | 07:08 AM
NmexMAX's Avatar
dot dot dot ...
Plug wires..
Old Nov 7, 2006 | 07:13 AM
scubasteve's Avatar
Originally Posted by NmexMAX
Plug wires..
I dont follow what point your attempting to make? A few people have suggested tune up as a remedy. Typically this includes the wires as well as the plugs. I don't see a tune up as a solution to his problem, so i said that "plugs, wires, etc" werent likely to be the answer.
Old Nov 7, 2006 | 07:16 AM
Luisjo's Avatar
Wow. now that you mentioned i did not had these problem before the intake. what i did was i took the sensor from the OEM filter ans plug it and the CEL went off so i will go ahead and give it one more week to see if the milage is the same. I didnt think it was that because 3 or 4 days after i put the intake the white smoke came (only when i accelrated rapidly or when i went into the highway) so i thought that it was only because its hot. Didnt think it was from the simple intake but since the CEL came on with that code only i have that bad milage.
Old Nov 7, 2006 | 07:18 AM
scubasteve's Avatar
Best thing you can do is put the stock intake back on.
Old Nov 7, 2006 | 07:21 AM
NmexMAX's Avatar
dot dot dot ...
VQ engines do not have plug wires.
99grnmaxgxe's Avatar
4th Gens don't have spark plug wires!
Old Nov 7, 2006 | 07:23 AM
NmexMAX's Avatar
dot dot dot ...
I wonder how many seconds that was off by
Today, 08:21 AM
Today, 08:21 AM
Old Nov 7, 2006 | 07:43 AM
scubasteve's Avatar
thats what i get for only having to do oil changes.....so how exactly does the plug connect to the coils? Learn something every day!
MaximaSE96's Avatar
Maxima Owner
for the 3rd time ARE U HAVING STARTING ISSUES...LIKE EXTENDED CRANK....and if u have smoke...it could be raw fuel...which could be leaky injector hence bye bye fuel
Old Nov 7, 2006 | 07:46 AM
scubasteve's Avatar
err, post #19
Old Nov 7, 2006 | 08:01 AM
Today, 08:21 AM
Today, 08:21 AM
That wasn't the first time too!
Old Nov 7, 2006 | 08:03 AM
MaximaSE96's Avatar
Maxima Owner
err, post #19
meh still could be an injector issue
Old Nov 10, 2006 | 03:10 PM
Luisjo's Avatar
so.. im taking the car sunday to determine what my car has, but i noticed something now i was at the highway and goingo like 60mph i noticed that i have the gas pedal like i was on circuit, so i think that maybe it is the pistons? i dont know for sure also mi car shuted down last night and it was a good 48 seconds (not a lot but people where honking like crazy) so my CEL wasn't on but when the car shutted and i (after hard work) started it again the CEL came on with code 0908 that is... Engine coolant temperature sensor. and i wanted to know. Is that bad or something i should take care of. or better yet does it has something to do with my bad gas milage. Thanks
Old Nov 10, 2006 | 03:19 PM
scrhale's Avatar
Get that changed. The car will continue to randomly shut off from a start and even cause the RPMs to dive down while driving.
