egr codes question....
Old Nov 6, 2006 | 10:20 AM
acidspit86's Avatar
i have an egr code, hi/low flow, does this affect performance at all, and what does it do when its clogged/low flow?
Old Nov 6, 2006 | 10:26 AM
L0R1DA's Avatar
EGR is something you should do research about because its sort of the proverbial double-edged sword. It keeps combustion chamber temps lower but basically reduces your power a notch. A clogged EGR tube will cause some mild attention-getting disturbances but nothing too serious. However, consistent deviation from manufacturer specifications can cause other problems and ecu codes. So to answer your question yes it affects performance (but not much), and you should clean it, because a clogged situation will mess with your vehicle's ecu operating program parameters.
Old Nov 6, 2006 | 10:31 AM
madisonmxma's Avatar
you definately want to fix the problem or you will have some detonation
Old Nov 6, 2006 | 11:34 AM
acidspit86's Avatar
what exactly do i clean? vacuum hoses and stuff? the egr valve itself?
Old Nov 6, 2006 | 10:10 PM
Garrick's Avatar
The WHOLE system. There was a thread about this started by I think his name was Soundboy or something. Research it and ye shall recieve.
Old Nov 6, 2006 | 10:26 PM
shadyonedeath's Avatar
http://www.google.com/coop/cse?cx=00...%3A3ncgvn5cyg4
Search EGR.
Great tool.
Old Nov 6, 2006 | 10:30 PM
f550maranello2's Avatar
check the egr tube.. it almost always is clogged and gibes this code... check all the vaccum likes as well
Old Nov 7, 2006 | 06:47 AM
Sounbwoy's Avatar
Somebody call me? LOL. Anyway, I drove with my code for the better part of a year with no noticeable side effects (for me). I still got decent gas mileage (27 and up mpg), car started, did several long distance runs with no issues. That said, it still needs to be addressed and if you live in a state where you have annual inspection, you might as well go ahead and do it now. The thread I started is somewhere around and I do have pictures, so hopefully it will help. I have to say again, I wouldn't have found without the help of other Org members.
Old Nov 7, 2006 | 11:01 AM
nhaven's Avatar
Here's what I did to get rid of 0302, worked in my case.
http://forums.maxima.org/showthread.php?t=496494
Old Nov 8, 2006 | 11:07 AM
acidspit86's Avatar
you are awesome man i wish i could send you some money or something. thanks a ton, i think that is what was throwing the code, as mine looked just as dirty as yours
Old Nov 8, 2006 | 08:10 PM
Sounbwoy's Avatar
OK. Here are my pictures.
FWIW, I didn't cut or use a hacksaw on anything. Whatever works best for you is what you should do.
Here's the thread I started when I was working on mine..
http://forums.maxima.org/showthread....t=egr+sounbwoy
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
