Vibration between 700-900 RPM...
Old Dec 5, 2006 | 08:37 PM
ComradeJew's Avatar
Hey all,
I just noticed I have a slight but noticeable vibration occurring between 700-900 RPM. I at first thought it was clutch chatter - but now I am not 100% sure. I know it's not the motor mount as that one is fine and was torqued to spec. I have cleaned the throttle body though so I am wondering if that may be the cause.
It's not very significant but still something I'd want to be sure about.
Old Dec 6, 2006 | 03:52 AM
323MaximaSE's Avatar
knock sensor?
Old Dec 6, 2006 | 08:21 AM
ComradeJew's Avatar
Knock sensor causing vibrations like this only in that RPM? Acceleration seems normal... I'll try and pull a ghost code - but I haven't seen any so far.
Old Dec 6, 2006 | 10:15 AM
ComradeJew's Avatar
Anyone has any other ideas?
Old Dec 6, 2006 | 12:11 PM
Apparition's Avatar
Ichiban King
I wonder if its the vibration that Black Maxima, some others, and myself were having. We were betting on it being the Y-pipe hitting something, either that or some weird tranny problem.
It was inconclusive.. I still have no problems and it's been happening for a long time, which for me almost confirms my exhaust suspicions.
Old Dec 6, 2006 | 12:24 PM
ComradeJew's Avatar
I can't really see how it can be an exhaust issue since I didn't touch it during the clutch swap (started after clutch swap).
Old Dec 6, 2006 | 01:46 PM
speed racer's Avatar
how bout taking it apart again. Could be a bad install.
Old Dec 6, 2006 | 02:06 PM
ComradeJew's Avatar
Highly doubt this is a bad install since we triple checked everything - only the engine vibrates and only at those low RPM... I checked codes - got 0505 which I assume is "ALL IS OKAY, YO!"
I think it may be due to the clutch still in the break in period - doesn't bother me really.
Old Dec 7, 2006 | 08:32 AM
ComradeJew's Avatar
Last attempt to get anyone's suggestions
Old Dec 7, 2006 | 08:39 AM
SonicDust187's Avatar
I started to have same problem after I changed my clutch. What clutch are you guys running? I have a Spec Stage 2 setup.
Old Dec 7, 2006 | 08:47 AM
ComradeJew's Avatar
5th gen exedy OEM kit.
Old Dec 7, 2006 | 10:57 AM
99se5speed's Avatar
SHIFT_up
Alex you have that problem with spec? I gotta meet up with you so that you can "diagnose" my set-up...i might be in the same boat as several of you guys. I'll find you on AIM.
Old Dec 17, 2006 | 03:08 PM
shilov's Avatar
I just started having exectly the same vibration at low rpm. My tranny failed a couple of weeks ago and these are the things I have had replaced in the car:
- tranny
- clutch kit
- drivers side axle
Also the fly wheel was resurfaced. And now I have this annoying vibration. Could the mechanic screwed something up when installing the clutch kit/fly wheel ? Something off center?
I don't have any trouble codes.
Old Dec 17, 2006 | 05:34 PM
matrix11229's Avatar
Hey all,
I have the same problem since my alternator and belts were replaced by mechanic. Everything was smooth before but after the repairs I noticed vibration in N and D especially in 700-900rpm range and I could feel a slight vibration in steering wheel when driving up to 2000rpm.
First I thought they installed bad alternator so I bought one on ebay and they installed it for me but I didn't feel any difference. 5 mechanics were looking at my car alltogether and those a$$holes told me they don't know what's wrong with the car.
So I found that adjusting the alternator belt tension helped to significantly reduce the vibration.
After I loosen the belt tension, there is almost no vibration. I'm gonna loosen it a little bit more next weekend.
Old Dec 17, 2006 | 07:42 PM
heynow's Avatar
very interesting, perhaps this is the same kind of vibration that i'm experiencing.
Old Dec 19, 2006 | 07:56 AM
shilov's Avatar
Can anyone tell me if this vibration can be caused by improper installation of a clutch kit/flywheel ? If so I can try taking it back to the mechanic and demanding a reinstall.
Old Dec 19, 2006 | 08:44 AM
99se5speed's Avatar
SHIFT_up
yes, it is possible. But if they used a clutch alignment tool then it techincally shouldn't happen. I don't think the shop will do anything about it for something so little and insignificant, especially since it'll take them a while to take apart your tranny again.
user 11122324
42
Jul 18, 2022 03:35 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
06maxima55
Sep 28, 2015 04:29 PM
alahjahwan09
18
Sep 21, 2015 09:12 PM
Bonka
Sep 14, 2015 11:18 PM
