Which headlight bulb to buy?????
Old Dec 7, 2006 | 03:22 PM
indeep's Avatar
Hi there I bought these headlight bulbs from this store it cost me 35 dollars cnd those were not bad for a while, they gave out blue bright light you can say and after a while it ran out and seems to burn down my socket aswell. Can someone tell me which bulb to buy this time? that will not burn my socket and give out a nice bright light. And also what if i put nice bright light on my taillights would that make a difference and give out nice light? and how much would it cost cnd.
thankss
Old Dec 7, 2006 | 04:07 PM
Dave H.'s Avatar
Well, like what has been said before, Sylvania Xtravision's (maybe $20/pair) are always good.
You could do a 9007 conversion with Xtravision to get even better lighting. Sylvania Silverstars look great during good conditions, but don't work well in the rain and some complain of their short life span.
Those are the only ones I have experience with so that is all I can contribute.
I currently use the Xtravisions and am pleased with them, but I hope to go with HID's someday.
Dave
Old Dec 7, 2006 | 04:21 PM
Garrick's Avatar
9007 or HID's are always good. Check my signature.
Old Dec 7, 2006 | 04:22 PM
indeep's Avatar
bulb
So is the PIAA bulbs good also? and whats the easiest way to convert into 9007? can you show me I'm not a really a expert I looked up in a sticky couldnt really know what to do.
thanks
Old Dec 7, 2006 | 04:27 PM
indeep's Avatar
my corners are not even that bright how did you do that? is it cause you have the clear corner?
Old Dec 7, 2006 | 04:28 PM
Garrick's Avatar
Basically there's a couple of wires you have to switch around and clip off the extra nub on the 9007 bulb with nail clippers. That's when I used to have 9007's I like my HID's now. That was a b***h to make.
Old Dec 7, 2006 | 04:32 PM
Garrick's Avatar
http://forums.maxima.org/showthread.php?t=312531
Literally took me two minutes. Google will be your best friend. You have much to learn grasshopper. Enjoy.
Old Dec 7, 2006 | 04:36 PM
Garrick's Avatar
Compare that with my sig, you can the see the difference I hope. There were street lights in the bottom ones and my lights still powered through.
Old Dec 7, 2006 | 04:42 PM
indeep's Avatar
what bulb are you using for your corners and headlights? does it make a difference for the taillights also? so I guess the PIAA bulbs are not good..
Old Dec 7, 2006 | 04:51 PM
Garrick's Avatar
PIAA's are fine. For the 9004 or even 9007 I used Sylvanias. They're really good. Mine are HID's; that's a whole different ballgame.
Old Dec 7, 2006 | 05:49 PM
99grnmaxgxe's Avatar
Just stay away from anything that's over 100w, so they won't melt your harness.
Old Dec 7, 2006 | 08:20 PM
95_Maxima_5spd's Avatar
I did a 9007 conversion on mine and am running Hella bulbs...the light output is real bright, clear, and far-reaching. If you can find them, i would definately recommend them....i think i picked mine up for $35-40.
good luck
Old Dec 7, 2006 | 09:07 PM
LiGhtSoUt's Avatar
9007conversion with some silverstars and you should be fine
Old Dec 7, 2006 | 10:49 PM
FantasyGod's Avatar
Stay away from bulbs over 65w or if they are blue or yellow tinted. Overwattage bulbs are going to continue melting your wiring harness and tinted bulbs... well it's kind of like tinting your windshield and expecting to see better out front. Convert to 9007 and stick to clear bulbs.
Old Dec 8, 2006 | 05:40 AM
maximized98's Avatar
Addicted to the Org
i like the nokya arctic white bulbs, i have used these on numerous cars and love them, but get the stage 1, so it will be stock wattage. i had the stage 2, and could not tell a difference, but my harness could.lol
Old Dec 8, 2006 | 06:06 AM
NissanMan97's Avatar
DO A RETRO!!!
Old Dec 8, 2006 | 06:27 AM
jvelos3's Avatar
Originally Posted by NissanMan97
DO A RETRO!!!
I second the motion to retro!!!
Old Jan 1, 2007 | 12:14 PM
supreme5101's Avatar
would it be easy to do the 9005 to 9007 upgrade with the jegs 9007 harness???
AaronL
Nov 15, 2020 11:52 AM
Vistance
Sep 17, 2015 05:17 AM
meccanj98
Sep 16, 2015 07:23 AM
kjlouis
Sep 14, 2015 11:22 AM
minsbang
Sep 11, 2015 08:48 PM
