Rear Caliper Frozen?
Old Dec 12, 2006 | 12:07 PM
BigTDogg's Avatar
I was attempting to do my friends 98 GLE rear rotors and pads yesterday. The passenger side caliper would not come off the rotor. At all. I disconnected the ebrake cable, removed the two 17mm bolts, and even pried a little. Checking to see my procedure was correct, I released the cable from the driver side, removed the bolts, and the caliper would slide off near effortlessly.
He complained of a noise in the rear of the car, and with the caliper being so stuck, I'm thinking it's frozen on. 98 GLE with about 120k on the clock. Can anyone confirm that the caliper is frozen? Or is there something wrong with my procedure.
Any help is apprecaited, thanks in advance.
Old Dec 12, 2006 | 12:10 PM
MaximaSE96's Avatar
Maxima Owner
new caliper time....they freeze up often...especially with 120k...i have done both of mine....does the piston turn at all
Old Dec 12, 2006 | 12:19 PM
BigTDogg's Avatar
I didn't even take it off the rotor. I wanted him to be able to drive home. I'll get a pair of calipers, and check the piston movement once I have it off the car. These are groved pistons correct? As in, I either need a special tool to spread and twist, or needle nose pliers to twist as I push, right?
Thanks for the quick reply!
Old Dec 12, 2006 | 12:25 PM
MaximaSE96's Avatar
Maxima Owner
yessir they are....no need to push though...its like a screw just twist
Old Dec 12, 2006 | 12:37 PM
natty99's Avatar
Yeah, the piston doesn't just push right in....you need to turn it AS you are pushing it in. Some people have used needle nose pliers but I'd be too scared of marring the outside of the piston and consequently having the seal get some tears. There is a tool you can buy that attaches to a rachet and fits inside the piston, allowing you to turn it:
http://www.sjdiscounttools.com/kd3163.html
Old Dec 12, 2006 | 12:53 PM
BigTDogg's Avatar
Natty, nice link. Thanks!
Old Dec 12, 2006 | 12:55 PM
MaximaSE96's Avatar
Maxima Owner
or if ur a baller
http://buy1.snapon.com/catalog/item....re&dir=catalog
Old Dec 12, 2006 | 12:56 PM
MaximaSE96's Avatar
Maxima Owner
or if ur a baller
matts95max
Apr 23, 2025 10:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
bbsitum
Sep 11, 2015 04:55 PM
beerman1378
Sep 8, 2015 02:19 PM
