A/F Gauge
Old Dec 12, 2006 | 03:28 PM
XAugusta MoonX's Avatar
A/F Gauge
I recently bought an air/fuel gauge from iEquus and I tried finding an install thread but to no avail. I was wondering if anyone knew which wire I needed to tap to get a signal, or if it would be easier to tap each O2 sensor separately. If that's the case, where does the other O2 sensor connect? I'm getting wideband sensors soon but I just want to see how I would go about this. The instructions that came with the gauge were for a 4 wire O2 sensor btw.
Old Dec 12, 2006 | 03:29 PM
Correction, other O2 sensor means bank 1 sensor 2
Old Dec 12, 2006 | 05:56 PM
matts95max's Avatar
If I remember correctly you need the wideband unit..not just the sensor for you to get any kind of correct reading
Old Dec 12, 2006 | 06:02 PM
NmexMAX's Avatar
dot dot dot ...
Old Dec 12, 2006 | 06:05 PM
Well yeah, I would need two, right? I mean, there are 2 pre-cat sensors...
Old Dec 12, 2006 | 06:10 PM
NmexMAX's Avatar
dot dot dot ...
How are you planning on providing them a signal input in order to control A/F?
Old Dec 12, 2006 | 06:32 PM
Apexi NEO is what I'm looking at. I just want a gauge to monitor more easily rather than changing screens or whatever on the NEO.
Old Dec 12, 2006 | 06:35 PM
matts95max's Avatar
the neo isnt a wideband
http://forums.maxima.org/showthread.php?t=498048
read that thoroughly.
Old Dec 12, 2006 | 06:39 PM
NmexMAX's Avatar
dot dot dot ...
Old Dec 12, 2006 | 07:00 PM
As far as I've read on Apexi's site it can act as a wideband controller
Old Dec 12, 2006 | 07:01 PM
I do appreciate the thread though
Old Dec 12, 2006 | 07:08 PM
matts95max's Avatar
...show that
Old Dec 12, 2006 | 07:09 PM
NmexMAX's Avatar
dot dot dot ...
It's far more complicated than that.
Originally Posted by matts95max
...show that
Not found ---> http://www.apexi-usa.com/product_ele...=260&pageNum=1
Old Dec 12, 2006 | 07:20 PM
matts95max's Avatar
ok you can use the neo to adjust your a/f ratio. but the neo will not tell you what your current a/f ratio is. that is why you need a wideband. The wideband gets the reading and then displays it via a guage or screen. Some can datalog so that you can record what is going on while you are driving so that you can go back later and adjust the settings with your neo.
Old Dec 12, 2006 | 08:21 PM
Alright thank you.
Miket2006
Mar 1, 2021 03:55 AM
220k+ A32
18
Sep 22, 2015 11:39 AM
RWCreative
Sep 21, 2015 11:01 AM
kadespraggins
Sep 14, 2015 12:04 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
