HID question
HID question
i was wondering if there was a write up's on installing non projector hid for my max (like the hid's on a 2001 acura cl). are they just plug n play, what about the the high beams, bixenons??? sorry i dont know much about this kind of stuff. also what about the beam pattern, if it can be done i'm sure it has been.
ill explain...
First....... dont get the kits they are crap.. all of them.. you are gonna be blinding people when u drive the housing is not meant for HID..
Second... you loose ur highbeams....
Third go visit www.hidplanet.com and read up on some stuff there they have a boat load of information....
if your thinking that its easier or cheaper....its not.
retrofitting actual projectors is the easiest and cheapest to have a good HID set up.
if your thinking that putting in a 9004 HID kit is good...its not.
beam pattern is not existant....cutoff is non existant...and basically...you will just have light everywhere...not good.
do that retrofit...itll cost u about $300-500 depending on which projectors u want to go with. and putting them into the headlight is not that hard. it just takes some common sense.
your right, it most likely would, how much do you think that would run me altogether, headlights and all. also how involved would it be to setup a dual projector setup. i wouldnt want to spend the money on those already nice looking brand new head lights just to ruin them.
so itll be about ~750
and for the r34 headlights...i expect the dual retro to be a bit easier than stock lights....there are individual compartments for the projectors.
what you could do with teh r34 are just do a single projector and use the high beams of the r34 as your highs. it would save you $100.
or you could use ur stock headlights with either a dual or a single bi xenon if you want to keep ur high beams. ull save $240.
there are a lot of ways to do the retro...
you basically will need
1.) dremel, cutoff discs (i recommend the carbon fiber reinforced ones)
2.) drill
3.) mask and goggles
good luck...let us know if u have any other questions.
trsandrew
Apr 8, 2016 06:45 PM
Unclejunebug
Apr 2, 2016 05:42 AM
trsandrew
Oct 25, 2015 02:47 PM
Stagnet04
Oct 11, 2015 08:16 PM
