skeptical about the venom 400..
im looking at chips online and ive found a few possibilities but im still a little skeptical about them and the one im leaning towards most is the venom 400, if anyone has a chip in there car if you could post the name of your chip and where you got it and if it was worth it.
thanks alot guys.
thanks alot guys.
nobody has a chip in their car on here becasue they do absolutely nothing. But you could test out that venom 400 and tell us how it goes. Should have searched before you posted this one.
I like kettle and baked....I have to go with kettle tho
the only chip application that I have seen make a noticeable difference, was on a B5 Passat. It cranked the boost up to like 17psi, and it was incredible. It was even a wagon!
A JWT chip in an NA maxima is useless. You at least need FI to make it worth while with modified fuel maps, etc.
But no really, kettle cooked mesquite BBQ. Respect.
Its hit or miss since they dont have the car with them so tuning can be off.
Yeah hmmm, I'm gonna have to go ahead and disagree with you on that. It makes a marked difference on NA cars, actually far more than on many boosted cars since their timing scheme especially their program for z32 MAF and 555cc injectors is so severely neutered.
I don't understand what you are trying to say. JWT ECUs for NA cars run significantly advanced timing while JWT ECUs for FI applications run significantly retarded timing. The timing schemes are nowhere near the same.
It doesn't advance it out of the range acceptable for use with pump gas, it just advances it over what the stock timing curve is. JWTs 555cc/z32maf program has timing retarded over 14 degrees in some areas.
Safc 1 or 2, cannot adjust timing, along with the VPC/GCC, MapEcu, only thing that does adjust timing is full EMS like Aem or Motec or HKS FCON PRO, the rest are just piggy backs, allowed to adjust fuel above certain increments
i had a VPC/AFC, now im on Map Ecu, next up is Aem ems
You can even indirectly adjust timing with SAFC II - pulling or adding fuel via maf conditioning indirectly changes ignition timing. There are datalogs available from those who have done it with SAFC II.
I sure haven't been running 15+ pounds of boost on stock timing on 93 octane pump gas
- I'm pulling timing with my emanage blue.
I've heard of speed chips, many people dont have possitive feedbacks of speed chips so i kinda stay away, i say you just go ahead and get an ECU upgrade, it would do you better, and if you still lean towards a speed chip let me know how it worked out
Im having trouble finding one from TS or an E-manage for my 95, actually cant find one for any maxima. I could be blind, but apparently not made for the maxima at all. Did find one from JWT though... expensive, is it worth it? How many extra HP on a stock 95 with a cold air?
Greg's2kGLE
Feb 9, 2002 10:08 PM
PRINCE NISMO
Nov 22, 2001 11:18 AM
Toolrocks
Oct 15, 2001 11:15 AM
tune yourself.
