Exedy stage 2 install question?
Old Dec 22, 2006 | 07:30 AM
5spd99seL's Avatar
The install and everything went smoothly, but after bleeding, I noticed a considerable amount of extra play in the peddle. Is this due to the stronger pressure plate? If so, the only way to get rid of the play is to adjust the peddle closer to the floor? Anyone who has an aggressive clutch let me know if they experienced a similar peddle feel. Thanks
Old Dec 22, 2006 | 06:58 PM
5spd99seL's Avatar
bump anyone?
Old Dec 23, 2006 | 03:43 AM
mastercater7's Avatar
VQ35 FTW
i have the same clutch and noticed it for sure
Old Nov 11, 2008 | 03:39 PM
99BlackMaxMS's Avatar
Bringing this back from the dead because I have the same problem. We adjusted the clutch pedal where it should be set to, however it it even with the dead pedal.
I know there are people on here running this clutch, where did you end up setting your pedal at? I know you can adjust it to sit closer to you, but wouldn't that cause the clutch to slip?
PH98I30
Jan 9, 2025 08:08 AM
Matt93SE
May 24, 2019 02:58 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
sc10692
Aug 9, 2015 09:37 AM
Blackwind
Aug 5, 2015 06:35 PM
