Setting O/D off as default
Old Dec 26, 2006 | 04:22 PM
InsneDrmr's Avatar
I know there was a way to do it, does anyone recall?
Old Dec 26, 2006 | 05:09 PM
kcryan's Avatar
Why..just out of curiousity?
Old Dec 26, 2006 | 05:22 PM
2da mizzax's Avatar
its really easy. hit the button.
Old Dec 26, 2006 | 05:55 PM
EnervinE's Avatar
i has college
Uh...the button stays out when you press it, keeping O/D off. Am I misunderstanding what you're asking?
Old Dec 26, 2006 | 07:24 PM
InsneDrmr's Avatar
Hahaha...Well alright, I noticed driving around town the car kinda fumbles through gears because of all the stop and go garbage, but when the O/D is off it doesnt do it as bad, because its one less gear to have to deal with.
Basically what I want is when I turn the car on, to automatically have overdrive off, instead of having to push the button everytime I turn the car on.
This was brought up a few times last year. I just cant seem to find the posts. Does anyone know how to set the car that way?
Old Dec 26, 2006 | 07:39 PM
EnervinE's Avatar
i has college
I'm really starting to think you have a different O/D button than me. Mine is like a pen, you push it once and it pops out, disengaging O/D. When you turn the car off, it stays pushed out, so when you start the car next, O/D is already off.
Old Dec 26, 2006 | 08:07 PM
triumphD6's Avatar
+1. Seems pretty easy to me, unless your button is broken.
Old Dec 26, 2006 | 08:49 PM
kcryan's Avatar
Hmm, mine works by pushing it once, it turnd OD off, then push it again turns it back on, if i leave it off, and turn the car off the car automatically turns it back on....
Old Dec 26, 2006 | 09:02 PM
EnervinE's Avatar
i has college
I wonder if it was changed for the '98 model year.
Old Dec 26, 2006 | 09:21 PM
gen4maxima536's Avatar
i think it was, my 98 o/d button is a momentary switch, unlike the one in my 96 that was an in/out switch
Old Dec 27, 2006 | 12:25 AM
kpjg588's Avatar
You just need to change the switch.
Old Dec 27, 2006 | 01:05 AM
nguyen925's Avatar
er....wtf?
Old Dec 27, 2006 | 04:09 AM
InsneDrmr's Avatar
yea the switch is different, sorry for the confusion.
so you think a switch change would do it?
Old Dec 27, 2006 | 04:46 AM
njmaxseltd's Avatar
That wount work either. I had an aftermarket shifter with a locking switch, unlike my 99's simple push type. It didn't matter if the switch on the a/m unit was locked in or out. When the car was restarted o/d was always engauged.
Old Dec 27, 2006 | 07:32 AM
triumphD6's Avatar
well then that clarifies the confusion . . . my '97 is either in/out, doesn't reset itself upon startup. NOt sure how to fix that.
Old Dec 27, 2006 | 10:34 AM
EnervinE's Avatar
i has college
Buy a 97 so you can be cool like me.
Old Jan 1, 2007 | 02:05 PM
supreme5101's Avatar
does the car drive different when its in OD then not being in OD??????
Old Jan 1, 2007 | 02:18 PM
kcryan's Avatar
above 40ish it does
Old Jan 2, 2007 | 09:25 AM
L0R1DA's Avatar
Ok, it seems that the original poster needs to better inform himself as to the function of electronic overdrive in an auto trans. Although some mechanics of the system remain dubious to me, the basics of the concept of overdrive means a smaller gear driving a larger gear (more torque, less speed), and underdrive means a larger gear driving a smaller gear (less torque, more speed). When you engage O/D you're actually ELIMINATING a gear by distributing that gear's ratio to the remaining 3 gears (higher ratio is more torque). When your O/D is OFF you have 4 gears, that are less torquey. Personally, I enjoy keeping O/D on at lower speeds, and turning it off when on the highway for the joy of direct drive (engine and tires turn as same speed). Keep in mind, an overdrive condition is designed to keep your engine speed lower by providing a mechanical advantage (more torque multiplication), with O/D off you will have nicer response but your tachometer will show higher engine speed, which effectively burns more fuel. As for your question of engagement laziness... your idea is completely worthless since it takes one quick thumb movement to engage/disengage. Good luck!
Old Jan 2, 2007 | 09:43 AM
kpjg588's Avatar
wtf
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
knight_yyz
Nov 1, 2015 01:34 PM
Stagnet04
Oct 11, 2015 08:16 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
