Air is getting in to my clutch fluid....where could it be comming from?
Old Dec 30, 2006 | 07:09 PM
ManualMaxima's Avatar
5th Gen till she dies!
Sometimes when i walk out to mt car in the morning my clutch is on the floor. I have to pump it quickly with my hand for about 30 seconds to build pressure up......so i bled the clutch....and it was perfect for about 2 days and slowly air started getting back into the system.....so i bled it again....and it take about 2 to 3 days to go back to being limp pedal in the morning.....where could the air be comming in from?
i was thinking myabe the clutch line, cause it is old...but i see no fluid leaks on it or anything..
Old Dec 30, 2006 | 07:18 PM
njmaxseltd's Avatar
It's probably the clutch master cylinder. Make sure your not loosing fluid anywhere. Check around the lines and the slave cylinder. If you see no sign of fluid leaks and the system doesn't appear to lose any fluid, then replace the master cylinder.
Old Dec 30, 2006 | 07:30 PM
i recently put a new slave and master cylinder on cause of this problem, and it did fix it......so i do not think it is either of them...
Old Dec 30, 2006 | 09:35 PM
Apparition's Avatar
Ichiban King
Missing wind deflector..
Lines themselves, or line fittings?
maxima-junky
Oct 21, 2015 05:17 PM
95Maxi
Aug 29, 2015 09:38 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
maxima-junky
Aug 13, 2015 09:59 AM
