Alarm Beep using REGULAR Horn?
Old Dec 31, 2006 | 04:00 PM
kaneda_77's Avatar
I've tried searching via google in hopes of finding discussion on here about such a project, but was unsuccessful. Maybe after the next couple paychecks, I will be able to afford to be a donating member....lol.
Wouldn't it be possible to hook the factory installed horn up to the relay so that the car horn actually sounds when the FOB remote locks the doors? The write-up using the buzzer is great, but I was thinking that it could be done using our horn and basically just a little extra wiring to the front. Any other ideas or experiments by you guys?
Old Dec 31, 2006 | 04:14 PM
EnervinE's Avatar
i has college
Why would you want to...the factory horn sounds
Old Dec 31, 2006 | 05:50 PM
kaneda_77's Avatar
Well maybe you can get a confederate flag and get the General Lee horn.... maybe a gun rack on the back? YEEEEEEEEEEEEEEEEEEEEEHAAaaaaaaawwww!!!
Anyway, it's louder and can be heard from farther away... plus it's another project that ppl might be interested in.
Old Jan 1, 2007 | 02:38 PM
maxima_kenny96's Avatar
.....agree w/ kaneda
Old Jan 1, 2007 | 02:48 PM
kaneda_77's Avatar
So I was thinking, that as an adjustment to the normal mod. You could route wiring that was going to the buzzer mechanism to the fuse/wiring where the horn is located. I don't see why such a thing wouldn't work. Hopefully, some of the electrical geniuses can provide some input.
Old Jan 1, 2007 | 04:39 PM
Tyrexx's Avatar
NO Unless you completely rewire your stock horns.
Alarm beep = 2X 12V pulse
Horns = switched ground
Old Jan 1, 2007 | 07:24 PM
kaneda_77's Avatar
You're saying that the horn is triggered by grounding the signal right? Couldn't a rig be setup to ground when the lock is triggered? Doesn't seem like you'd have to re-wire everything. I think it's interesting enough to explore, but before I do anything I hope to have enough discussion and background(hopefully some diagrams) to do it. Then I could make a FAQ for other users.
Old Jan 1, 2007 | 07:42 PM
RA030726's Avatar
I'm nutty for Nissans
Its totally doable with relays. The wire from the BCM sends ground, the horn trigger is 12v+ so:
Relay pin diagram:
86 12v+ constant
85 BCM flash signal
87 horn wire
30 12v+ constant
Old Jan 5, 2007 | 09:29 AM
kaneda_77's Avatar
got any pics that correspond to the numbers? I think we're pretty close to having enough info for me to stumble through the 2nd phase of this.
Please guys, if you have any technical input, don't hesitate to post. Speculation and theories could end up completing this mod.
Old Feb 5, 2007 | 09:36 AM
Deckdout2's Avatar
Play with my balls
Or you can just get this module from me.
http://forums.maxima.org/showthread.php?t=509714
KabirUTA13
19
Oct 17, 2015 02:15 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
05RLS2
Sep 27, 2015 09:24 PM
foodmanry
Sep 24, 2015 12:02 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
