Brake line rubbing against RSB?
Old Jan 5, 2007 | 02:00 PM
aznprid972's Avatar
Hey guys, I was installing my spring/shocks the other day and noticed both my rear brake lines seems almost cut. I think it might be rubbing against the Stillen RSB but I'm not sure exactly why. Is it the bolt or is it the blue clamps? Anyone else having this issue?
Old Jan 6, 2007 | 10:57 PM
aznprid972's Avatar
bump.. Anyone know what's the cause?
Old Jan 7, 2007 | 12:10 AM
Chunger's Avatar
My other car is a Hybrid
Cause is obvious...
You may want to replace that line and protect the new one with wire wrap or loom like I did on my SS brake lines.... you may be able to "twist" the line so it is further away from the RSB bracket by "pretensioning" the attachment at the upper end of the hose...
Old Jan 7, 2007 | 05:55 AM
njmaxseltd's Avatar
Originally Posted by Chunger
Cause is obvious...
You may want to replace that line .....
Absolutely replace that line!
Old Jan 7, 2007 | 10:46 AM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
Get a new line and use a zip tie to pull it up and away from the bracket.
Old Jan 7, 2007 | 11:12 AM
aznprid972's Avatar
I don't understand why this happened when it was at stock height. Can I pick up the lines to both sides in the rear at any parts store or do I have to buy it in a kit or some sort?
Old Jan 7, 2007 | 11:19 AM
Vlasic's Avatar
It doesnt matter what height your at. That whole rear assembly moves up and down when you hit a bump or a dip in the road. You obviously ran over something big enough to push that bracket into the brake line. Just go buy a line from kragen or a local parts shop.
Old Jan 7, 2007 | 03:20 PM
Chunger's Avatar
It's rubbing up against the Stillen RSB mount... the blue anodized "clamp"...
Replace it with OE type line or you could spring for complete set of braided lines anyways because you have to rebleed the brake system anyways...
Old Jan 7, 2007 | 04:01 PM
aznprid972's Avatar
I wonder if I could sand down the edge of the clamp so it won't happen again. Thanks guys for the responses!
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
