Hose threatened? (picture)
Old Jan 5, 2007 | 02:47 PM
EnervinE's Avatar
i has college
The hose being bent by the bar is in concern. #1, what is the black piece it is connected to, and #2, is there a way to adjust that piece to be out of the way?
Or is it really not a problem/in danger?
Old Jan 5, 2007 | 03:25 PM
Fr33way™'s Avatar
Wild for Width
Bend the bracket.
When the engine revs it will want to tilt backward, it is hitting the bar as you drive.
Old Jan 5, 2007 | 03:52 PM
MDeezy's Avatar
I agree with fr33way, bend the bracket. That will certainly get broken one day when you gun it, and the motor leans back and that slaps right into the bar.
Old Jan 5, 2007 | 03:59 PM
EnervinE's Avatar
i has college
Those big hoses are holding that piece in TIGHT. The bracket metal just slips around the piece.
I'll try bending the hoses around. Took it for a 4k rpm test drive and it didn't get touched, but I'll figure out a precaution. Thanks for the info.
Old Jan 5, 2007 | 05:54 PM
WaarrEagle's Avatar
Bend the bracket. I did not and the black piece eventually broke from hitting the FSTB. I forget what it is, but I had to buy a new one.
Old Jan 5, 2007 | 06:12 PM
RA030726's Avatar
I'm nutty for Nissans
One way or another youll need to move that valve unless you fell like buying another.
Old Jan 5, 2007 | 06:41 PM
Fr33way™'s Avatar
Wild for Width
You were driving while standing in the engine bay? It's touching.
Old Jan 5, 2007 | 07:10 PM
RA030726's Avatar
Nah hes got one of those clear hoods.
Old Jan 5, 2007 | 07:11 PM
Fr33way™'s Avatar
Wild for Width
Forward tilting TFATF hood for the ultimate e-props.
Old Jan 5, 2007 | 07:31 PM
MaximaSE96's Avatar
Maxima Owner
yea mine broke.........EVAP Purge Control Valve.........need new one
Old Jan 5, 2007 | 07:36 PM
nitromax's Avatar
when i looked at mounting my fstb, i noticed the mounts offset the bar either closer to the firewall & the brackets or if i switched the mounts to the other strut towers it would be offset toward the radiator away from the brackets. so of course i mounted it that way, away from anything.
Old Jan 5, 2007 | 09:49 PM
EnervinE's Avatar
i has college
Yeah, tune the NOS timing, I'll run 9's...
Old Jan 6, 2007 | 01:14 AM
Nealoc187's Avatar
SLOW
Sorry I thought you just misspelled "hoes" for a second there...
Old Jan 6, 2007 | 03:01 PM
Fr33way™'s Avatar
Wild for Width
That's why we need Jesse on the board. No one has figured out the Nos timing.
Old Jan 6, 2007 | 03:14 PM
MDeezy's Avatar
its in the stickies guys jeezz. . . you with the proper jet size set to spray right at TDC, or at the lastest its spraying into the cylinder when the piston is at 1* ATDC.
Guranteed 9's everytime.
doesnt anyone check the stickies anymore
Old Jan 6, 2007 | 07:21 PM
the_3d_man's Avatar
bend the bracket. My strut bar was rubbing that exact spot and it eventually rubbed a hole in that hose. So bend the bracket a little to avoid that.
Old Jan 6, 2007 | 08:37 PM
nismology's Avatar
That's hot.
Miket2006
Mar 1, 2021 03:55 AM
bigfrank
Oct 1, 2015 12:51 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
