Will these NGK's work?
Old Jan 5, 2007 | 02:52 PM
Da_Shatterer's Avatar
I've been looking into doing alot of my 97 Max's 60k tune up myself and have been reading up on all the tools/parts I would need. I know everyone recommends NGK as the preferred style of spark plugs, but are THESE the ones that everyone is talking about? The reason I'm a little bit unsure is because I've read that people are spending close to 8-9 bux a pop on OEM replacement platinum spark plugs and was able to find these for less than 3 bux each online. Any input would be greatly appreciated. Thanks.
Also, is there a big enough difference between platinums and iridiums to warrant the price being two times as much?
Old Jan 5, 2007 | 03:01 PM
2da mizzax's Avatar
http://www.ngksparkplugs.com/product...200&country=US
these are the preferred ones if you are going copper. if not, get the dealer set (PFR5G-11 ) or some iridiums. the "part finder" link will show you which ones.
Old Jan 5, 2007 | 03:13 PM
Ahhhh so I take it the dealer ones are actually the laser platinum and not g-power platinum version right?
Old Jan 5, 2007 | 03:18 PM
2da mizzax's Avatar
correct. but again the concensus is that it is more economical and you get equal or better performance with the coppers. the iridiums (denso or NGK) are said to give both better performance and longevity.
Old Jan 5, 2007 | 03:21 PM
But are Iridiums really all that to warrant that much of a price difference when say compared to the coppers?
Old Jan 5, 2007 | 03:31 PM
2da mizzax's Avatar
i havent used them, but i cant see them making that much difference. and they only last about twice as long but cost more than twice as much. I would go to Autozone and get the coppers. cant beat a $12 plug change that runs as good or better than factory.
Old Jan 5, 2007 | 03:41 PM
Sounbwoy's Avatar
I'm using the G-Powers with no issues. They're also platinum, so the question comes down to the amount of platinum in the plug.
Old Jan 5, 2007 | 03:42 PM
kcryan's Avatar
Platinums, not iridiums should be used, unless you dont mind changing them every 20-25k...I speak from experience with all of the above (iridiums were not in this car, but i reccomend against them unless you have alot of boost)
Old Jan 5, 2007 | 08:15 PM
shiftnatredline's Avatar
Godzilla
yeah i was looking at getting the NGK iridium laser cut.. so are you guys saying that the coppers are better??
Old Jan 5, 2007 | 09:53 PM
scrhale's Avatar
Iridiums should be used for moderate+ usage of NOS or moderate+ amounts of boost. Not for N/A or very low boost or small shots of NOS.
Even in the cases of low level boost/NOS, you would use 2-3 step cold Coppers.
Get the OEM plats
For the record, has anyone ever found NGKs in the Espanol-Zone (Autozone). Seems like they are Bosch fans there.
Old Jan 8, 2007 | 01:18 AM
fithos's Avatar
Get the OEM plats
None of the autozone I went to ever carry the NGKs.
Old Jan 8, 2007 | 06:02 AM
PAMudslinger's Avatar
I know NAPA carries NGK brand. They use a 4 digit sku# so depending on what you are wanting to run here are the numbers.
Standard BKR5ES-11 2382
V-Power BKR5E-11 6453
G-Power BKR5EGP 7090
Iridium "IX" BKR5EIX 5464
OE Style
Platinum PFR5G-11 2647 (Nissan#22401-1P115)
Iridium IFR5E-11 7994 (Not sure as to why they are refering to as OE)
All of these numbers are from NGK and are for '95-'01 Maxima's.
Old Jan 8, 2007 | 08:06 AM
Sounbwoy's Avatar
found mine at Advance Auto- the Autozone near me has them in the computer, but they have to be ordered.
MAXSE5SPD
Sep 17, 2022 04:00 AM
mvm062
Nov 30, 2020 09:00 AM
Hailstatejig
Sep 2, 2015 06:52 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
kenc15
Aug 5, 2015 08:29 AM
