Brake pad problem.
Brake pad problem.
Hello guys! I heard some weird noise coming from the right rear everytime I hit the brake. Then I went to auto repair shop to check out the problem. The guy told me that the weird noise is caused by the aftermarket brake pad. He told me to change to brake pad to original Nissan one. He wanted to charge me 120 dollars for the rear pads. He said that may solve the weird noise problem. Any comments are welcome. Thank you.
I have had Raybestos ceramics on my rears for 4 years and no issues at all!! Try giving it a shot, FYI, I replaced my fronts with the same ceramics, giving it the break in period and after 200 miles, it is as good as my Hawk HPS that was there on it earlier.
Always get the expensive one. I find that they are much better. Or from the dealer but I found that the best ones from NAPA are better than dealer sometimes I just got a max and I had a honda and that is where I found out this. The last person to have this car got cheap pads and they are making a bit of noise too I am going to be replacing mine shotly.
don't let anyone touch your brakes... do them yourself. Get good pads and shims and put them on yourself, and it will cost you way under 100 bucks (for rears only). Afterwards go out to a road with no traffic and bed them in real well.
Is it even possible to bed in rear pads? I wouldn't think they would get hot enough.
I would get a 2nd opinion.
The noise you hear in the rear occurs when you apply the brakes?
Originally Posted by 2da mizzax
you shouldnt worry about "bedding in" the fronts either. all a myth.
you are right. new pads will nev er wear down to an even surface with the rotor without a driver speeding up and slowing down like an idiot.
thats why all shops get in your car and "bed them in" before you come and pick it up after a pad change.
you are right. new pads will never wear down to an even surface with the rotor without a driver speeding up and slowing down like an idiot.
That's not what bedding in is about, it's about getting the pads and rotors hot enough to transfer the brake pad material evenly to the rotor.
Originally Posted by dgeesaman
Shims dampen and stop vibration.
I think the bedding thing is pretty much a waste of time on OEM type pads.
Dave
Dave
Street pads are much, much softer than the rotors. They 'bed in' very quickly, unless the rotors are bad. They operate at low temps and as such they tend to operate by mechanical wear and friction. So bedding in a street pad is nothing more than the profiles wearing in to match each other exactly. The proof is that you'll see your cast iron rotor pick up rust - if there was a transfer going on, the cast iron would be sealed by brake pad material. But that hasn't happened - the rotor surface rusts instantly.
Track pads are much harder and operate more based on getting to extremely high temps and transferring some material to the rotor. Then in operation, the adhesive friction between the pad and transferred layer are what create most of the friction. The bedding in process is about building up enough heat to get the transfer layer started and establish proper adhesive friction.
Really, seriously, you should consider whether you understand this subject enough to refute others.
Dave
Dave
Apr 16, 2020 05:15 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
