Preventing Rust
Old Jan 21, 2007 | 04:09 PM
Jesse729's Avatar
Preventing Rust
Ive noticed there aren't too many threads on rust so I was just wondering a few things. I have no visible rust on my car yet but it's 8 years old I have noticed some rust inside the rear wheel wells and some in the under body . I'm going to wash the under body of my car soon to get rid of all the salt then I'm going to some rust protector anywhere I see rust. I'm just wondering from those of you who have had visible rust what rusts first and is there any way to prevent it?
Old Jan 21, 2007 | 04:14 PM
MDeezy's Avatar
there is an underbody spray treatment you can get done to your car to prevent rust.
Old Jan 21, 2007 | 05:08 PM
Maxgig's Avatar
I don't have big spots of rust because I attack any rock dings I find right away. But here in KS I have seen some Max's with bad rust around the rear wheel wells and on one particular car the bottom portion of the drivers door is rusted pretty bad. I've found that washing the under carriage real good and keeping your wheel wells clean plays a big part in helping to slow down rust.
Old Jan 21, 2007 | 05:49 PM
dgeesaman's Avatar
Maintenance Monster
Every spring, lift the front of the car some and hose out every nook and cranny you can find in the lower part of the engine bay that could collect grit, dirt, leaves, and water. Don't get the intake and electrical stuff - I'm talking frame components.
A lot of rust comes from water trapped on metal, trapped by an accumulation of road gravel or leaves. Especially check the front crossmember that supports the radiator. As long as the stock drain holes don't get plugged up, the car will no pretty well.
Dave
Old Jan 22, 2007 | 03:11 AM
2da mizzax's Avatar
old mechanics trick i was taught. spray it down with used motor oil. the undercariage and inside of the fender/doors. smells for the first couple of days but creates a nice layer.
Old Jan 22, 2007 | 09:26 AM
dgeesaman's Avatar
Maintenance Monster
Boy, those must be some greasy, smelly mechanics you hang out with.
Used motor oil is really toxic stuff, it's probably best not to leak any more of it on the roads than is necessary.
Dave
RealityCheck
Oct 2, 2015 06:34 PM
uttadms31
Sep 30, 2015 05:24 AM
worldwiderecognized
Sep 24, 2015 06:56 PM
