uh....i think the fluid in my brake lines froze!!
Old Jan 26, 2007 | 06:01 AM
heynow's Avatar
Hey guys, i had a pretty scary experience this morning. I start my car, it's 16 degrees out here (brrr). Car starts fine, but i was in a real hurry so i couldn't let it warm up. I depress the brake pedal, go into "D" and try to make a U-TURN. I come close to a parked car and try the brakes. The damn pedal is as hard as a rock! I pushed it down as hard as i could, and finally stopped.(almost hit a parked car!!) I tried braking a couple of times and the pedal loosened up and was ok after pressing the pedal 3 times. After that it was fine (Actually better, the pedal got less mushy!!!). I'm guessing that the brake fluid froze somewhere in the lines? I was complaining about my brake pedal feeling mushy after my mech changed both my rear calipers. Last i checked, my brake fluid level was in spec. Maybe my mech let a little air in while he was changing my calipers.
Old Jan 26, 2007 | 06:27 AM
Greeny's Avatar
¯\(°_o)/¯
Most brake fluids have a freezing point of between -40/-50 F
Might be a faulty brake booster?
Old Jan 26, 2007 | 06:40 AM
heynow's Avatar
oh i sure ****ing hope not!!
Old Jan 26, 2007 | 06:57 AM
MaximaSE96's Avatar
Maxima Owner
i dont think so...I have superblue racing fluid and it was 7 degees this morning and i didnt have an issue
Old Jan 26, 2007 | 07:03 AM
ArcticW's Avatar
I almost steered into someone's lawn two mornings ago when this happened to me.Since the brakes and fluid are in good shape, I deduced it to be simply a stuck or frozen pedal linkage of some kind. Cars do strange things in subzero weather. I wouldn't worry about it happening again.
Simply warm your car, or floor the brake pedal when you shift out of Park, and all should be well.
BTW, your engine oil would freeze before your brake fluid would.
Old Jan 26, 2007 | 07:07 AM
86maxima96's Avatar
I Broke OT
no, freezing fluid is out of the question. 16 degrees is nothing. i've headed off to class in the morning at sub zero temps and no problems. the pedal definitely felt better as it warmed up, though.
Old Jan 26, 2007 | 07:44 AM
heynow's Avatar
okay, so no reason to panick (yet). The brakes are fine, they're actauly feel firmer and have become more responsive.
Old Jan 26, 2007 | 09:35 AM
Nealoc187's Avatar
SLOW
If something froze in your brake lines it was water in your brake lines, brake fluid isn't going to freeze at any realistic temperatures. Flush your brake fluid with new fluid.
Another possibility is water on one or more of your calipers froze and wouldn't let the piston extend.
Old Jan 26, 2007 | 10:48 AM
phenryiv1's Avatar
Mod her. Ate her.
ALL of your answers are in this post.
Old Jan 26, 2007 | 05:07 PM
shiftnatredline's Avatar
Godzilla
Def. since brake fluid absorbes water and since your mech changed the calipers air+water would freeze. btw there is air in your lines if it feels mushy. go back and complain and tell him to bleed the whole system. While you're at it just tell him he messed something up and have him replace all the brake fluid.. lol
Old Jan 26, 2007 | 06:21 PM
heynow's Avatar
lol, i dunno, the dude's my neighbor, and i've bugged him enough already! It actually felt firmer on my way back home. The car brakes well, it's just that it seems that i need to push the pedal down more than i used to
Old Jan 26, 2007 | 06:38 PM
buzpuck11's Avatar
Brake problems are nothing to ignore. If it doesn't feel right, go bug him, your safety as well as others depends on it.
Old Jan 26, 2007 | 07:52 PM
willard00's Avatar
ya deff wasnt frozen. this morning here with wind chill it was about -10. i didnt have time to let the car warm up either...and i didnt have any problems.
Old Jan 26, 2007 | 09:09 PM
heynow's Avatar
i guess i'll ask him
Old Jan 27, 2007 | 06:13 AM
dgeesaman's Avatar
Maintenance Monster
You're having a hydraulics problem. When the master cylinder starts to go, it will tend to go in the coldest temps and the seals are most contracted.
Get the master cylinder replaced and have the system bled. It's the only safe way to proceed. Also have all 4 brake lines inspected.
Dave
Old Jan 27, 2007 | 10:12 AM
heynow's Avatar
Thanks Dave!
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
imported_Nismo_max
Sep 20, 2015 08:19 AM
Johnny9595
Sep 16, 2015 07:20 PM
