This sucks...
Old Feb 3, 2007 | 04:14 PM
HarrisH's Avatar
This sucks...
I started noticing a small leak around my driver side area. It would leave a small drops overnight. I got it looked at today and my mechanic told me my rack & pinion is leaking. I always used Synthetic Power Steering fluid and the car has 165K miles on the rack and pinion.
Should I just replace the rack & pinion with a new '99 SE one or should I just do a flush and add some power steering stop leak? What do you guys think?
Old Feb 3, 2007 | 04:16 PM
kcryan's Avatar
Try the stop leak, cant hurt i dont think
Old Feb 3, 2007 | 04:21 PM
2da mizzax's Avatar
Stop leak may worl and we dont use PS fluid. we use ATF.
Old Feb 3, 2007 | 04:30 PM
kcryan's Avatar
Early systems did use PS fluid i thought
Old Feb 3, 2007 | 04:40 PM
sky jumper
I would start by flushing the system with DexronIII ATF - the proper fluid. this may solve your leak. I'm guessing the leak is related to your use of non-approved PS fluid. I personally would avoid the stop leak, last thing you want is your pump getting gummed up.
Old Feb 4, 2007 | 12:07 AM
ssr123456's Avatar
I'm no expert, but I replaced my rack and pinion on my 97 maxima a couple days ago at 103k miles. Basically I had a lot of shaking left and right in the steering wheel, especially noticeable when I was on the freeway. If you don't have that problem, don't replace it. I read some reviews about the place I took my car to saying it was fair and honest, but I paid $400 bucks just for the part itself and probably a couple hours of labor. Rip-off? Probably. I don't want to talk about it.
Old Feb 4, 2007 | 09:30 AM
dgeesaman's Avatar
Maintenance Monster
Where is it leaking? If it's leaking from the PS hoses, then reposition each hose clamp and retighten.
If it's leaking from the inner tie rod boot, find a new rack.
Dave
Old Feb 4, 2007 | 09:41 AM
HarrisH's Avatar
I'm contemplating replacing it because the steering doesn't feel that loose. Or maybe that's just my imagination and it can be tighter. The leak is from the driver's side by the boot it's definitely leaking from the rack.
Old Feb 4, 2007 | 01:59 PM
dgeesaman's Avatar
Maintenance Monster
If it's leaking from the rack replace it. Mine was pretty loose feeling, and replacing the rack pretty much solved it. Get the 99, and maybe get a rebuilt one. Used is taking a gamble, and after doing that job I wish I had done a rebuilt 99 instead of a lower mileage 97 rack.
The downer is that replacing the rack requires dropping the front end of the y-pipe and some joyous wrenching in tight spots. It's DIY'able but have your ratcheting box wrenches handy.
Dave
Old Feb 4, 2007 | 03:59 PM
HarrisH's Avatar
Should I get just the "rack" or the whole "steering rack". The difference in price between the two is ten-fold.
Old Feb 5, 2007 | 09:37 AM
HarrisH's Avatar
Bump to the top anyone?
Old Feb 5, 2007 | 10:05 AM
2da mizzax's Avatar
I think you should flush it (a real flush with some transtune and using the return line) and then put in some stop leak. If that doesnt work, or if that is not what you want to do, take it to the same mechanic and find out which part it is that will needed to be replaced.
Old Feb 5, 2007 | 12:08 PM
sky jumper
let me repeat - you have the wrong fluid in there. maybe if you flush it out and put the correct fluid in your problems will disappear. a fluid change is cheap and easy. a new steering rack is not.
Old Feb 5, 2007 | 12:10 PM
2da mizzax's Avatar
I charge $20 + materials for a flush.
and not that turkey baster crap either.
pavelbarchuk
21
Aug 30, 2012 04:10 PM
Lontar1
Mar 30, 2009 11:31 AM
