Car dies on start? VID inside.
Old Feb 28, 2007 | 11:09 AM
udienow's Avatar
After the car has been sitting outside for a long time in the cold this usually happans. Its not always that it does this. In the vid I do not touch the throttle in the first start attempt. I do give it gas (obviously) the 2nd time after the RPMs dipped to under 500.
http://s21.photobucket.com/albums/b2...iesonstart.flv
Thanks for any input. Im guessing its some kind of ban sensor. My check engine light is on, but it is on for my rear o2 sensor. Also this only happans on the initial cold start. Once the car runs for even a few mins it is fine and starts right up.
Old Feb 28, 2007 | 11:33 AM
QBridge's Avatar
This is a common problem. I had it. Just take some throttle body cleaner and a tooth brush and clean the inlet on the intake. Mine stopped dying after I did that. There is a write up here about it. You also have to clean a valve but I didn't clean it on mine but it works fine now.
http://forums.maxima.org/showpost.ph...27&postcount=2
Old Feb 28, 2007 | 08:30 PM
udienow's Avatar
I cleaned my throttle body recently. So I know its not that.
Old Feb 28, 2007 | 10:36 PM
97MaximaSE97's Avatar
I used to have that problem. I cleaned the throttle body and used seafoam and it went away. It's starting to come back after a year though. The rpms just dip but it hasn't died yet.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Maxboy23
Aug 11, 2015 11:59 AM
